Java problem
Defqon
Java problem
Post by Defqon » Sat Mar 07, 2009 3:09
Hey guys, I'm having a problem running any Java command.
I've searched Google extensively, and haven't been able to find a solution that works for me.
I'm using Sabayon Pod.
Anyways, when I run "java" in Terminal, here is the output:
* Home for VM 'sun-jdk-1.6' does not exist: /usr/lib/jvm//sun-jdk-1.6
* Invalid System VM: sun-jdk-1.6
Does someone want to help me figure out how to properly install Java?
Thanks,
-Blake
Re: Java problem
Post by wolfden » Sat Mar 07, 2009 3:58
augh POD, you picked the worst one to download
http://www.gentoo.org/doc/en/java.xml
