how to install opera 10...
Postby perrillo » Thu Feb 26, 2009 17:27
hi! like i said...how to install opera 10 alpha on pod 3.5 :?: also i CAN'T configure xorg.conf :x i got 1280x1024 but in my /etc/X11/xorg.conf doesn't appear that option I WANT 1024x768 hope some answers :idea:
perrillo
Re: how to install opera 10...
Postby micia » Thu Feb 26, 2009 19:42
could you please tell us your graphic card and some info on your drivers?
Opera 10 is available with portage, I recommend you to read some documentation before
using emerge.
On the 3.5 POD you also have to setup portage before being able to use it,
more info on:
http://wiki.sabayonlinux.org/index.php?title=En:HOWTO:_3.5_Pod_adding_portage
micia
Postby perrillo » Thu Feb 26, 2009 20:50
hi there!
intel but if u need more info tell me what\how to do :?: perhaps some command :idea:
perrillo
Postby micia » Thu Feb 26, 2009 21:06
Well, Sabayon has a "convention" on gathering log files and info, see this HOWTO:
http://forum.sabayonlinux.org/viewtopic.php?f=56&t=15530
for your own use,
these commands may help you on gathering info on your setup:
eselect opengl list
lists all your openGL implementations on the system, with a '*' next to the current one,
you can set the, for example, ati one with:
eselect opengl set ati
eselect is a very powerful tool.
There is an handy tool called 915resolution (available in spritz/equo) get a look here: http://www.geocities.com/stomljen/
micia
