problems with hplip
zambayoni
problems with hplip
Post by zambayoni » Thu Feb 26, 2009 16:35
I has problems with hplip, when (superuser):
# /etc/init.d/hplip start
hplip                | * Starting hpiod ...
hplip                | * start-stop-daemon: /usr/sbin/hpiod does not exis [ !! ]
hplip                | * Starting hpssd ...                               [ !! ]
hplip                | * ERROR: hplip failed to start
I see in google and http://www.gentoo-wiki.info/HPLIP, and not found references to this error.
I tried start cups before and after that, but still gives the same error. Some idea about this problem ?
xlnagla
Re: problems with hplip
Post by xlnagla » Fri Mar 06, 2009 17:34
Sabayon and CUPS do not really use hplip currently, though indeed it should be supported in theory - for what pupose do you wish to use the service?
~xlnagla
zambayoni
Post by zambayoni » Mon Mar 09, 2009 0:20
I removed hplip service, becuase this service not is necessary for me. Really, I thought that hplip was necessary with HP device manager, but was not. Hplip is for other things
Thanks for reply :D
