tool to develop with C c++ or Java
Postby carotapacioccia » Mon Feb 23, 2009 11:46
Hi guys I was used to write code with net beans, but I could not find it in sabayon,
I tryied to install eclipse but eclipse sdk seems only to work for java and I need to compile under C...
any suggestion?
...pls don't respond ... vim / nano / kate / :cyclops:
carotapacioccia
Re: tool to develop with C c++ or Java
Postby Thev00d00 » Mon Feb 23, 2009 12:01
kate is awesome! btw.
Eclipse is my suggestion for you, even though its written in the evil language
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
Thev00d00
Generally Awesome (tm)
Postby carotapacioccia » Mon Feb 23, 2009 14:28
first, thanks for the rep...
as I found on spritz eclipse is the only choose (have not found net beans...)
so im using version 3.4.1 java eclipse sdk ,
but i think its weird the way they have done things...
have you installed some plugin or something like that to build a c project?
I am not able to find nothing!
carotapacioccia
Postby Thev00d00 » Mon Feb 23, 2009 16:54
twitter: Follow Me
G+: Circle Me
Thev00d00
Postby micia » Mon Feb 23, 2009 19:01
micia
Postby zambayoni » Tue Feb 24, 2009 5:11
carotapacioccia wrote:Hi guys I was used to write code with net beans, but I could not find it in sabayon,
any suggestion?
If you want install netbeans:
1. Check that has installled a Sun JDK 6 in Sabayon ( in repositories see dev-java/sun-jdk ,and for more information see http://www.gentoo.org/doc/en/java.xml)
2. Download Netbeans for http://services.netbeans.org/bouncer/index.php?product=netbeans-6.5&os=linux , this is a instalable binary package for any distro that have Sun JDK 6
3. Install from shell (superuser), typing the name of downloaded .sh file
But for a C and C++ simple programs, i use GNU Emacs with editing code directly, and editing makefile and executing make command to build (GNU Make), and if the program is more complicated, you can learning about GNU autoconf and GNU automake, but these are advanced topics for building in C and C++ and other languages. The proffesional programmers use this form of building programs.
See for more information about these GNU tools
http://www.gnu.org/software/emacs/manual/emacs.html
http://www.gnu.org/software/make/manual/
http://www.gnu.org/software/autoconf/manual/index.html
http://www.gnu.org/software/automake/manual/
zambayoni
Postby asygxwrhtos » Sat May 02, 2009 19:02
You can use cdt under eclipse (for C/C++); eclipse ganymede may be installed via equo and is the best choice for Java. For netbeans other users already gave you some instructions. If you are an average C/C++ programmer then codeblocks is the best choice. You can install codeblocks via equo.
-asygxwrhtos
asygxwrhtos
