Tracker daemon should be disabled by default
yuguang
Post by yuguang » Tue Feb 17, 2009 22:58
Anyone running gnome in LiteMCE will probably have this annoying thing that makes the hard drive click whenever a file is generated in their home directory. It's caused by the search and indexing, but can be disabled. http://www.howtogeek.com/howto/linux/wh ... t-running/.
This thing is actually quite useless unless you want to use the command line to search for files. (The gui is not available in Sabayon)
Thev00d00
Generally Awesome (tm)
Re: Tracker daemon should be disabled by default
Post by Thev00d00 » Wed Feb 18, 2009 10:02
Tracker is needed as a dep, if you can identify what needs it that would assit us.which GUI program is missing also?
This is an issue for the bugzilla. Please post on there
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
yuguang
Post by yuguang » Wed Feb 18, 2009 19:30
Obviously, nautilus needs it, but there's a way (always a way) to disable it in the USE flag.
http://gentoo-portage.com/gnome-base/nautilus/USE#ptabs
Next time Sabayon is doing a release, compile nautilus without the tracker and beagle USE flag, so Sabayon lovers won't feel like they are using Windows.
The easy way to turn it off to see what difference it makes is through System \ Preferences \ Indexing Preferences and unchecking the "Enable indexing" option. The deskbar USE flag makes searching convenient http://gentoo-portage.com/app-misc/tracker/USE#ptabs, though.
Thev00d00
Post by Thev00d00 » Wed Feb 18, 2009 19:42
Thev00d00 wrote:This is an issue for the bugzilla. Please post on there
twitter: Follow Me
G+: Circle Me
yuguang
Post by yuguang » Fri Feb 20, 2009 4:18
done. bug 511
Edit: I didn't consider this as a bug since I end up tuning things on every OS I use.
Thev00d00
Post by Thev00d00 » Fri Feb 20, 2009 9:33
Well I consider tracker to be a bug :D
And your saying that something that causes your system to be slow on a default install isnt a bug? .... That implies you WANT your system to be slow :D
twitter: Follow Me
G+: Circle Me
