Firewall-autorun
gledof
Firewall-autorun
Post by gledof » Wed Feb 11, 2009 3:30
Hello, I use:
# sudo update-rc.d firewall.sh defaults (iptables script in the following folder: /etc/init.d)
for autorun firewall script when the system start up. In Sbayon4, I cant did it. I found many differences in the sintaxys regarding others Linux. Can you help me with the wright command?
Re: Firewall-autorun
Post by wolfden » Wed Feb 11, 2009 6:28
See:
http://www.gentoo.org/doc/en/home-router-howto.xml
It has section there on iptables
curse
Post by curse » Wed Feb 11, 2009 12:13
first, Sabayon is Gentoo based, not Debian based as Ubuntu, so the syntax is a bit different.
personally I prefer to su, and be root when I'm fixing stuff instead of the endless typing of sudo they do over in the Ubuntu camp.. though, that really doesn't matter.. the command you're looking for in this case is
rc-update firewall.sh default
zambayoni
Post by zambayoni » Wed Feb 11, 2009 21:10
i have a similiar problem. When super user:
#rc-update firewall.sh default
rc-update: service `firewall.sh' does not exist
In firewall.sh :
guarddog
I installed guarddog firewall.
gledof
Post by gledof » Thu Feb 12, 2009 1:08
You copied firewall script in the "/etc/init.d" folder? and gave it chmod +x?
gledof
Re: Firewall-autorun SOLVED
Post by gledof » Thu Feb 12, 2009 1:16
Curse, thank for the tip, of course I did it like a root, but I dont no why type "sudo". Tell me, there are a page where I can get a list of command for Gentoo (Sabayon) ?
zambayoni
Post by zambayoni » Thu Feb 12, 2009 15:04
gledof wrote:You copied firewall script in the "/etc/init.d" folder? and gave it chmod +x?
Yes, the script have the permissions to run, and is in the folder /etc/init.d. I can't do rc-update :?
zambayoni
Re: Firewall-autorun Solved reg service but problm with guarddog
Post by zambayoni » Thu Feb 12, 2009 16:48
I solved how register one service.
My problem was a bad script init.
I created /etc/init.d/firewall : (i look http://www.gentoo.org/doc/en/handbook/handbook-x86.xml?part=2&chap=4 and cupsd script)
#!/sbin/runscript
depend() {
   use net
start() {
   ebegin "Starting guarddog firewall ..."
   start-stop-daemon --start --quiet --exec /usr/bin/guarddog
   eend $?
stop() {
   ebegin "Stopping guarddog firewall ..."
   start-stop-daemon --stop --quiet --exec /usr/bin/guarddog
   eend $?
next do a rc.update_
 # rc-update add firewall default
 * firewall added to runlevel default
and response.!!! :D
If you remove a service, select option del for rc-update.
All is beautiful, but i have a small problem. When i rebooting, the firewall not starting.
Checking the script in terminal (super user):
 # /etc/init.d/firewall start
firewall             | * Starting guarddog firewall ... ...              [ !! ]
firewall             | * ERROR: firewall failed to start
My problem is the script or is the guarddog. It becuase guarddog is for KDE and suspect that work only in graph mode and searching for some options, but not find. I recording that firewall firestarter had a script for executing like service, i don't know if will have one for guarddog. :?
PD: When in terminal:
this work, and guarddog window open.
zambayoni
Re: Firewall-autorun [Solved]
Post by zambayoni » Thu Feb 12, 2009 17:17
yes, i solved my self :D
In http://bugs.gentoo.org/182373 i found the correct script for /etc/init.d/firewall:
#!/sbin/runscript
 depend() {
          after iptables
     before ddclient
 start() {
          ebegin "Applying firewall rules - Guarddog"
          /etc/rc.firewall
          eend $? "Firewall rules not set"
And Work!!! :D
Guarddog change IPtables and generate script in /etc/rc.firewall
Thanks :mrgreen:
zambayoni
Post by zambayoni » Thu Feb 12, 2009 18:14
