Storage Media won'd show on konqueror's sidebar [Solved]
Postby colector » Thu Jan 29, 2009 4:29
I'm using sabayon 4.0 and when I open konqueror on file browser mode the storage media tree wont display (or be available at all) on the side bar.
It will shot on the main widget but not on the tree view.
Check the pic in attach.
Any ideas?
thanks
colector
Re: Storage Media won'd show on konqueror's sidebar
Postby frisil » Wed Feb 11, 2009 16:44
right click under the star in the left sidebar, select "add folder". Right click the new folder and enter the address "system:/media" and the name "media". Then you got a media tab in the sidebar of konqueror. Voila!
frisil
Postby colector » Wed Feb 18, 2009 10:31
That worked just fine!
thank you =)
colector
Users browsing this forum: nomorelogic and 1 guest
