Unable to start mpd [Solved]
SathyaBhat
Post by SathyaBhat » Mon Jan 26, 2009 2:18
I've been unable to start mpd. It gives an error message as below
SHAMAN music # mpd start
problems opening file start for reading: No such file or directory
Attached is my mpd.conf file. Help would be very much appreciated.
Thanks.
Re: Unable to start mpd
Post by wolfden » Mon Jan 26, 2009 3:49
are you following the wki?
http://www.gentoo-wiki.info/MPD
your paths don't look correct at all
SathyaBhat
Post by SathyaBhat » Mon Jan 26, 2009 3:53
Hmm, I was following the Wiki @ mpd website. Will try what's mentioned in the link above and get back.
Thanks
SathyaBhat
Post by SathyaBhat » Mon Jan 26, 2009 5:48
Thanks for the wiki link, was able to start mpd.
The fast reply is much appreciated!
Re: Unable to start mpd [Solved]
Post by wolfden » Mon Jan 26, 2009 6:02
woot!
marking it solved than
:D
