VLC Not Integrating Interface
Gzus666
Post by Gzus666 » Fri Jan 23, 2009 1:15
OK, fresh install of Sabayon 4 RC1 64 bit. VLC won't integrate the control interface into the video window no matter what I do. I have tried to play with the integrate option in the settings to no avail. Force updated to the newest version .9.8a and still not fixed. Is there any way to force this or do I just have to wait? It was working normally in Fedora and previous 3.5F Sabayon.
Re: VLC Not Integrating Interface
Post by Fitzcarraldo » Fri Jan 23, 2009 1:38
Strange. I'm using vlc-0.9.1 under SL 3.5 'plus' (i.e. various upgrades, 2.6.27 kernel etc.) x86_64 and it's working OK for me.
Looks like it's not a problem limited to SL: see e.g. http://bbs.archlinux.org/viewtopic.php?id=56991
Gzus666
Post by Gzus666 » Fri Jan 23, 2009 1:50
Yea, in the previous 3.5F I had it working just fine. I looked it up all over the place and still got nowhere. Was hoping someone found a way around this cause I find VLC to be the best player I have tried.
Post by Fitzcarraldo » Fri May 15, 2009 16:55
Came across the VLC forum and it's a known bug in VLC for versions < 1.0.*: http://forum.videolan.org/viewtopic.php?f=13&t=51124
Apparently it's fixed in the 1.* version of VLC. vlc-1.0.0_rc1 is currently masked in Portage.
Thev00d00
Generally Awesome (tm)
Post by Thev00d00 » Sat May 16, 2009 11:58
Why do people use vlc? Its beyond me :o Smplayer is lighter on reasources, faster (it uses system libs) and more configurable.
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
kodiakmax
Post by kodiakmax » Sat May 16, 2009 18:42
Thev00d00 wrote:Why do people use vlc? Its beyond me :o Smplayer is lighter on reasources, faster (it uses system libs) and more configurable.
I agree I think VLC is highly overrated. Even in windows it's not the best player.
