Getting Bootchart to Work?
Postby Dark Star » Sat Jan 17, 2009 18:27
Hi
I installed Bootchart to compare Sabayon booting with that of other distro.. I installed bootchart from
equo install bootchart
It did install it.. But now I can't find an icon nor I can see the dump in /var/log so that I get the speed time of Sabayon 4 r1 :)
Do help me :)
Regards
Dark Star
Re: Getting Bootchart to Work?
Postby eshum » Sat Jan 17, 2009 20:12
Did you try typing bootchart in the menu search bar?
ed
eshum
Postby Dark Star » Sun Jan 18, 2009 3:31
I am using Gnome ed. I tried the command in Terminal but nothing happened . Apat from that despite all printer packages installed I wasn't able to add my Linux friendly HDP AIO 1410 printer and use it :twisted:
Dark Star
Postby DHalens » Sun Jan 18, 2009 4:36
The message after installing bootchart tells you to append something to your kernel comandline.
Looking for the files in the package shows there is only a binary: /sbin/bootchartd
localhost dhalens # equo install bootchart --quiet
>>  @@ Calculating dependencies ...
>>  @@ Packages needing to be installed/updated/downgraded: 1
>>  @@ Packages needing to be removed: 0
>>  @@ Download size: 0b
>>  @@ Freed disk space: 0.0b
>>  @@ You need at least: 115.9kB of free space
>>  :: (1/1) >>> app-benchmarks/bootchart-0.9-r2
>>  ++ (1/1) >>> app-benchmarks/bootchart-0.9-r2
 * To generate the chart, append this to your kernel commandline
 *    init=/sbin/bootchartd
 * and reboot
 * Post the file /var/log/bootchart.tgz here:
 *    http://www.bootchart.org/download.html
 * to render the chart
 * For best results:
 *   Enable BSD process accounting v3 in the kernel
 *     This will produce more accurate process trees
 *   Set AUTO_RENDER_FORMAT to svg in /etc/bootchartd.conf
 *     and view /var/log/bootchart.svgz with batik or
 *     Adobe SVG viewer. This will give you additional
 *     information about the processes in tooltips
>>  @@ Installation completed.
localhost dhalens # equo query files bootchart
>>  @@ Files Search...
>>  ### /etc
>>  ### /etc/bootchartd.conf
>>  ### /lib
>>  ### /lib/bootchart
>>  ### /lib/bootchart/.keep_app-benchmarks_bootchart-0
>>  ### /sbin
>>  ### /sbin/bootchartd
>>  ### /usr
>>  ### /usr/share
>>  ### /usr/share/doc
>>  ### /usr/share/doc/bootchart-0.9-r2
>>  ### /usr/share/doc/bootchart-0.9-r2/COPYING.bz2
>>  ### /usr/share/doc/bootchart-0.9-r2/ChangeLog.bz2
>>  ### /usr/share/doc/bootchart-0.9-r2/README.bz2
>>  ### /usr/share/doc/bootchart-0.9-r2/README.logger.bz2
>>  ### /usr/share/doc/bootchart-0.9-r2/TODO.bz2
>>  Package:    app-benchmarks/bootchart-0.9-r2
>>  Found:      16 files
DHalens
Postby joost » Sun Jan 18, 2009 23:24
I think the one in entropy doesn't work correctly.
to make it work do this:
emerge --sync
Inintial portage sync takes a while, only once
USE="java acct" emerge app-benchmarks/bootchart
I will get this fixed in entropy soon..
Oooh if you want to have it render the graph automaticly:
in /etc/bootchartd.conf :
AUTO_RENDER="yes"
thats why we compiled it with java support locally.
This also shows what you can do with sabayon.. :D
Postby joost » Sun Jan 18, 2009 23:55
i might need to take back what i just wrote above.
Besides it being compiled without the proper flags needed in Entropy..
Even compiled with those i have my doubts it could work on a openrc system.
Now i've done some diggin' around to know some people reported it working if they disable the /tmp to be cleaned at boot:
/etc/conf.d/bootmisc
wipe_tmp="NO"
Or add a variable to /etc/rc.conf:
RC_USE_BOOTCHART="yes"
Postby joost » Mon Jan 19, 2009 0:22
/edit
it doesn't work.
Only if i manually trigger
/sbin/bootchart start
time rc
/sbin/bootchart stop
then run
bootchart
it renders a chart that means nothing.
Well i think i can conclude it not working like expected with openrc.
