How to maually install a .bin application. [Solved]
Postby Ric » Fri Jan 16, 2009 0:39
To use the latest version of Blender, I downloaded the .bin from blender.org , and until now, I could just run it like that.
But after installing a few other apps ( via spritz), the system now thinks the Blender app is a "shared library"! It won't launch.
How install this application manually ?
Act weird. It supports freedom.
It gives others permission to act weird too.
Ric
Re: How to maually install a .bin application.
Postby wolfden » Fri Jan 16, 2009 3:34
You shouldn't be outside of the package manager.
Did you look in portage first? That would of been better than manually doing it.
If a package isn't in entropy you should look at portage or overlay to see if available. It's not recommended to mix them, but if you know what you're doing it's ok. I usually like to just create my own local overlay for packages outside of entropy. See the howto on 3rd party ebuilds. You can request packages and as far as version bumps, entropy is being bumped all the time, just a little patience is required. We just can't support packages that are manually installed, there is too many variables. We stress over and over and over to use the package manager.
:santa:
Postby Ric » Sat Jan 17, 2009 0:19
I tried, but got an odd blockage. One of the library dependencies is masked, portage needs updating before it would let me unmask.
I'll have to look into the 3rd party ebuild idea. I completely understand how much work it is to keep repositories up to date. Thanks for doing as much as you do. 8)
I just experimented with installing an older version with spritz, then replacing the .bin in user/bin with the updated version. I'm sure its a bad idea, but so far it's working well. Blender builds are mostly static fortunately. I may upgrade to SL 4 with KDE to get more up-to-date anyhow.
Ric
Postby albfneto » Sat Jan 24, 2009 17:18
Ric, your method is not so bad.
i make this sometimes, copying a new package over the old.
this is generally sucessuful, for ex, with some pre compiled packages for linux iin general, as the browser Firefox, or
the file manager Krusader.
You may also operate as Wolfden suggests, creating your local overlay, and in this manner, i have in mind that you may also fully update Portage.
I have at this moment 4 Sabayon installations.
One is 4.0r1, i use only Entropy.
Other is 3.5, fully updated to Branch 4, i use only Portage.
The two others were mixed, all works well.
Postby Ric » Mon Jan 26, 2009 2:21
Its nice to know it works. But I ended up upgrading to SL4 after all.
Then I noticed that Spritz has the ability to install from binary. (file/install from .bin... too obvious.)
Thanks anyhow guys.
Ric
Re: How to maually install a .bin application. [Solved]
Postby smardy » Tue Jan 27, 2009 17:16
Like blender myself .... :lol:
In fact
equo search blender
>>  @@ Searching...
>>   #1 Sabayon Linux Official Repository
>>      @@ Package: media-gfx/blender-2.48a-r3      branch: 4
It is in the repository so you can just equo install blender-2.48a-r3
or spritz must find it..
smardy
