openoffice suite will not load [Solved]
Postby sparkable » Tue Jan 13, 2009 18:46
This could be me just being new to linux but none of my open office programs will load on a newly installed Sabayon 4r1 system. I have a fully updated system and when I click on an icon it looks like it will load, but it never does. I checked in the terminal and it shows the programs are installed. Any one have any advice or possible solutions?
sparkable
Re: openoffice suite will not load
Postby joost » Tue Jan 13, 2009 21:54
Could you try this:
Open a terminal and type in
su
Give in your root password and do:
equo remove openoffice && equo install openoffice
Postby sparkable » Tue Jan 13, 2009 23:18
Sorry for not replying sooner, but i was doing what you suggested and it worked. Thanks alot for your help. Although I am curious as to why that occured. Was it a bad burn? or somethingelse? Again, thanks for your help.
sparkable
Postby joost » Tue Jan 13, 2009 23:20
I had a simular problem on sabayon4 and even on the Lite version we are testing now.
Simply reinstalling it on my machine like i told above solved it for me.. I thought it was only me.
:D
Postby sparkable » Tue Jan 13, 2009 23:25
Cool. That helped me make the switch to full-time linux user now that I can use openoffice. Great distro and cannot wait to
keep using as main OS. Now , I just have to learn more about package management.
sparkable
Postby joost » Tue Jan 13, 2009 23:29
Lemme give you a quick start.
to update the repos info:
equo update
This pulls in meta data about new packages available (and updates)
To update everything:
equo world
To install a single package
equo install package_name
to search
equo search package
:D
Postby sparkable » Tue Jan 13, 2009 23:34
Thanks :D
sparkable
Postby sparkable » Tue Jan 13, 2009 23:49
I got 2 more questions: should i use the emerge command or equo. Also, is there a good place to look for sabayon commands besides the wiki. When I used to ask question on other linux forums it would take days just to get a reply. Thanks again for all your help
sparkable
Postby joost » Wed Jan 14, 2009 0:04
Don't mix entropy (equo) and portage (emerge)
choose a path.
Since you are a newcommer (no offense at all) i suggest using entropy.
In entropy everything is pre-compiled. All problems taken careoff for you.
Portage has a learning curve, you can easily break your system with it, so if you want to try it, be sure to read the Gentoo manual.
Postby sparkable » Wed Jan 14, 2009 0:07
Good to know :D
Thanx
sparkable
