Openoffice 2.4 and 3.0.0-r1 crash on startup
mordjah
Post by mordjah » Tue Jan 13, 2009 3:52
Recently openoffice 2.4 has begun crashing on startup. this also happens with oo-3.0.0-r1.
I have tried the following:
remove all configs from home directory
run as root
force gnome window decorations ( export OOO_FORCE_DESKTOP=gnome )
update glibc ( on a side note, this threw a merge error, stating the build failed with the following :
  ## Ebuild: pkg_preinst()
/bin/date: relocation error: /lib/libc.so.6: symbol _dl_tls_get_addr_soft, version GLIBC_PRIVATE not defined in file ld-linux.so.2 with link time reference
 * ERROR: sys-libs/glibc-2.8_p20080602 failed.
 * Call stack:
 * ebuild.sh, line   49:  Called pkg_preinst
 * environment, line 3208:  Called die
 * "${D}"/$(get_libdir)/ld-*.so --library-path "${D}"/$(get_libdir) ${x} > /dev/null || die "simple run test (${x}) failed";
 * The die message:
 * simple run test (/bin/date) failed
 * A complete build log is located at '/var/tmp/entropy/packages/x86/4/sys-libs:glibc-2.8_p20080602~0.tbz2/portage/sys-libs/glibc-2.8_p20080602/temp/build.log'.
 * The ebuild environment file is located at '/var/tmp/entropy/packages/x86/4/sys-libs:glibc-2.8_p20080602~0.tbz2/portage/sys-libs/glibc-2.8_p20080602/temp/environment'.
 * This ebuild is from an overlay: '/var/tmp/entropy/packages/x86/4/sys-libs:glibc-2.8_p20080602~0.tbz2/'
>>    ## Installing package: sys-libs/glibc-2.8_p20080602
>>    ## Updating database: sys-libs/glibc-2.8_p20080602
>>    ## Cleaning old package files...
>>    ## Ebuild: pkg_postinst()
 * Generating locale-archive: forcing # of jobs to 1
 * Generating 2 locales (this might take a while) with 1 jobs
 *  (1/2) Generating en_US.ISO-8859-1 ...        [ ok ]
 *  (2/2) Generating en_US.UTF-8 ...        [ ok ]
 * Generation complete
>>    ## Regenerating /etc/ld.so.cache
>>    ## Updating {conf.d,init.d} mtime ...
>>    ## Cleaning: sys-libs/glibc-2.8_p20080602
>>  @@ Installation completed.
>>  @@ Caching complete.
but than said it installed fine.. )
here is the error output:
[email protected] ~ $ oowriter
[email protected] ~ $ terminate called after throwing an instance of 'com::sun::star::uno::Runtime
Exception'
error - missing word count in dictionary file
Hash Manager Error : 4
Running soffice directly gives a gdb dump:
[email protected] ~ $ soffice
Exception'
*** glibc detected *** /usr/lib/openoffice/program/soffice.bin: free(): invalid pointer: 0x0924
8c80 ***
======= Backtrace: =========
/lib/libc.so.6[0xb7bc9f07]
/lib/libc.so.6(cfree+0x72)[0xb7bcbae2]
/usr/lib/openoffice/program/../basis-link/ure-link/lib/libuno_sal.so.3(rtl_freeMemory+0x1a)[0xb
7e23369]
/usr/lib/openoffice/program/../basis-link/ure-link/lib/libuno_sal.so.3(rtl_uString_release+0x49
)[0xb7e2def9]
/usr/lib/openoffice/program/../basis-link/program/libspellli.so[0xaec8cf23]
/usr/lib/openoffice/program/../basis-link/program/libspellli.so[0xaec8dc64]
/usr/lib/openoffice/program/../basis-link/program/liblngli.so(_ZN22SpellCheckerDispatcher12isVa
lid_ImplERKN3rtl8OUStringEsRKN3com3sun4star3uno8SequenceINS6_5beans13PropertyValueEEEh+0x5e6)[0
xb0806bd8]
/usr/lib/openoffice/program/../basis-link/program/liblngli.so(_ZN22SpellCheckerDispatcher7isVal
idERKN3rtl8OUStringEsRKN3com3sun4star3uno8SequenceINS6_5beans13PropertyValueEEE+0xa5)[0xb08071a
5]
/usr/lib/openoffice/program/../basis-link/program/libsvxli.so[0xb01ffa94]
/usr/lib/openoffice/program/../basis-link/program/libswli.so[0xb0b6fcdd]
/usr/lib/openoffice/program/../basis-link/program/libswli.so[0xb0a39b0a]
/usr/lib/openoffice/program/../basis-link/program/libswli.so[0xb0a39e05]
/usr/lib/openoffice/program/../basis-link/program/libswli.so[0xb0a3e8f3]
/usr/lib/openoffice/program/../basis-link/program/libswli.so(_ZN9ViewShell10LayoutIdleEv+0xb6)[
0xb09e7ff0]
/usr/lib/openoffice/program/../basis-link/program/libswli.so[0xb0ae3848]
/usr/lib/openoffice/program/../basis-link/program/libvclli.so(_ZN5Timer7TimeoutEv+0x18)[0xb6d00
388]
/usr/lib/openoffice/program/../basis-link/program/libvclli.so(_ZN5Timer21ImplTimerCallbackProcE
v+0x89)[0xb6d00899]
/usr/lib/openoffice/basis3.0/program/libvclplug_genli.so(_ZNK10X11SalData7TimeoutEv+0x2a)[0xb51
e487e]
/usr/lib/openoffice/basis3.0/program/libvclplug_gtkli.so[0xb55c6371]
/usr/lib/libglib-2.0.so.0[0xb5809bf1]
/usr/lib/libglib-2.0.so.0(g_main_context_dispatch+0x1d5)[0xb5809387]
/usr/lib/libglib-2.0.so.0[0xb580b2ff]
/usr/lib/libglib-2.0.so.0(g_main_context_iteration+0x7c)[0xb580b3e0]
/usr/lib/openoffice/basis3.0/program/libvclplug_gtkli.so[0xb55c6115]
/usr/lib/openoffice/basis3.0/program/libvclplug_genli.so(_ZN14X11SalInstance5YieldEbb+0x2f)[0xb
51edc3f]
/usr/lib/openoffice/program/../basis-link/program/libvclli.so(_ZN11Application5YieldEb+0x57)[0x
b6cfc88b]
/usr/lib/openoffice/program/../basis-link/program/libsvxli.so[0xb02737df]
/usr/lib/openoffice/program/../basis-link/program/libsvxli.so[0xb0269276]
/usr/lib/openoffice/program/../basis-link/program/libsvxli.so[0xb03c321d]
/usr/lib/openoffice/program/../basis-link/program/libsvxli.so[0xb03c3651]
/usr/lib/openoffice/program/../basis-link/program/libsofficeapp.so[0xb7dc3aa3]
/usr/lib/openoffice/program/../basis-link/program/libsofficeapp.so[0xb7dc3b99]
/usr/lib/openoffice/program/../basis-link/program/libsofficeapp.so[0xb7dc8c29]
/usr/lib/openoffice/program/../basis-link/program/libvclli.so[0xb6d0008f]
/usr/lib/openoffice/program/../basis-link/program/libvos3gcc3.so(_ZN3vos26signalHandlerFunction
_implEPvP13oslSignalInfo+0x12)[0xb6c518e2]
/usr/lib/openoffice/program/../basis-link/ure-link/lib/libuno_sal.so.3[0xb7e20181]
[0xffffe400]
/lib/libc.so.6(abort+0x107)[0xb7b901d7]
/usr/lib/gcc/i586-pc-linux-gnu/4.3.1/libstdc++.so.6(_ZN9__gnu_cxx27__verbose_terminate_handlerE
v+0x158)[0xb7d5a458]
/usr/lib/gcc/i586-pc-linux-gnu/4.3.1/libstdc++.so.6[0xb7d58335]
/usr/lib/gcc/i586-pc-linux-gnu/4.3.1/libstdc++.so.6[0xb7d58372]
/usr/lib/gcc/i586-pc-linux-gnu/4.3.1/libstdc++.so.6[0xb7d584aa]
/usr/lib/openoffice/ure/lib/libgcc3_uno.so[0xb504689c]
/usr/lib/openoffice/ure/lib/libgcc3_uno.so[0xb5047914]
/usr/lib/openoffice/ure/lib/libgcc3_uno.so[0xb5047d1d]
/usr/lib/openoffice/ure/lib/libgcc3_uno.so[0xb5048792]
/usr/lib/openoffice/program/../basis-link/program/libsbli.so[0xb6b3ec38]
/usr/lib/openoffice/program/../basis-link/program/libsbli.so(_ZN5basic23ScriptExtensionIterator
28implGetNextUserScriptPackageERb+0x36)[0xb6b2fb74]
24nextBasicOrDialogLibraryERb+0x3a)[0xb6b3033a]
/usr/lib/openoffice/program/../basis-link/program/libsbli.so(_ZN5basic19SfxLibraryContainer18im
plScanExtensionsEv+0x1e0)[0xb6b33470]
/usr/lib/openoffice/program/../basis-link/program/libsbli.so(_ZN5basic19SfxLibraryContainer9ini
t_ImplERKN3rtl8OUStringERKN3com3sun4star3uno9ReferenceINS7_5embed8XStorageEEE+0x1a95)[0xb6b3acf
7]
/usr/lib/openoffice/program/../basis-link/program/libsbli.so(_ZN5basic19SfxLibraryContainer4ini
tERKN3rtl8OUStringERKN3com3sun4star3uno9ReferenceINS7_5embed8XStorageEEE+0x2f)[0xb6b3ce55]
/usr/lib/openoffice/program/../basis-link/program/libsbli.so(_ZN5basic25SfxScriptLibraryContain
erC1ERKN3com3sun4star3uno9ReferenceINS3_5embed8XStorageEEE+0xd6)[0xb6b440f8]
/usr/lib/openoffice/program/../basis-link/program/libsbli.so(_ZN5basic14ImplRepository34impl_cr
eateApplicationBasicManagerEv+0x515)[0xb6af66ad]
/usr/lib/openoffice/program/../basis-link/program/libsbli.so(_ZN5basic14ImplRepository26getAppl
icationBasicManagerEb+0x43)[0xb6af6ad7]
/usr/lib/openoffice/program/../basis-link/program/libsbli.so(_ZN5basic22BasicManagerRepository2
6getApplicationBasicManagerEb+0x26)[0xb6af73e8]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZN14SfxApplication15GetBasicMana
gerEv+0x35)[0xb770e9a5]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZN14SfxApplication8GetBasicEv+0x
1a)[0xb770e9c4]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZN14SfxApplication14EnterBasicCa
llEv+0x2d)[0xb770ea01]
gerEv+0x28)[0xb770e998]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZN14SfxObjectShell19SetCurrentCo
mponentERKN3com3sun4star3uno9ReferenceINS3_10XInterfaceEEE+0x76)[0xb778ff2e]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZNK12SfxViewShell18SetCurrentDoc
umentEv+0x35)[0xb7803c0b]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZN12SfxViewShell8ActivateEh+0x9c
)[0xb7805174]
======= Memory map: ========
08048000-0804a000 r-xp 00000000 fb:00 357586     /usr/lib/openoffice/program/soffice.bin
0804a000-0804b000 r--p 00001000 fb:00 357586     /usr/lib/openoffice/program/soffice.bin
0804b000-0804c000 rw-p 00002000 fb:00 357586     /usr/lib/openoffice/program/soffice.bin
0889f000-0933b000 rw-p 0889f000 00:00 0          [heap]
aeba7000-aec38000 rw-p aeba7000 00:00 0
aec38000-aec6b000 r-xp 00000000 fb:00 162294     /usr/lib/libhunspell-1.2.so.0.0.0
aec6b000-aec6c000 r--p 00032000 fb:00 162294     /usr/lib/libhunspell-1.2.so.0.0.0
aec6c000-aec70000 rw-p 00033000 fb:00 162294     /usr/lib/libhunspell-1.2.so.0.0.0
aec75000-aec84000 r-xp 00000000 fb:00 1276552    /usr/lib/openoffice/basis3.0/program/libhyphen
li.so
aec84000-aec85000 r--p 0000f000 fb:00 1276552    /usr/lib/openoffice/basis3.0/program/libhyphen
li.so
aec85000-aec86000 rw-p 00010000 fb:00 1276552    /usr/lib/openoffice/basis3.0/program/libhyphen
li.so
aec86000-aec93000 r-xp 00000000 fb:00 1276732    /usr/lib/openoffice/basis3.0/program/libspelll
i.so
aec93000-aec94000 r--p 0000d000 fb:00 1276732    /usr/lib/openoffice/basis3.0/program/libspelll
i.so
aec94000-aec95000 rw-p 0
Fatal exception: Signal 6
Stack:
/usr/lib/openoffice/program/../basis-link/ure-link/lib/libuno_sal.so.3[0xb7e1ffe7]
/usr/lib/openoffice/program/../basis-link/ure-link/lib/libuno_sal.so.3[0xb7e200d8]
/usr/lib/openoffice/program/../basis-link/ure-link/lib/libuno_sal.so.3[0xb7e201a6]
[0xffffe400]
/lib/libc.so.6[0xb7bc4822]
7e23369]
)[0xb7e2def9]
xb0806bd8]
5]
0xb09e7ff0]
388]
v+0x89)[0xb6d00899]
e487e]
51edc3f]
b6cfc88b]
[0xffffe400]
7]
1a)[0xb770e9c4]
)[0xb7805174]
/usr/lib/openoffice/program/../basis-link/program/libswli.so(_ZN6SwView8ActivateEh+0x1e1)[0xb0f
81fbb]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb7843c3e]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb7835122]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZN12SfxViewFrame10DoActivateEhPS
_+0x33)[0xb781e29f]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb770d523]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZN12SfxViewFrame12SetViewFrameEP
S_+0x22)[0xb7817e9a]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb781bba1]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZN11SfxTopFrame14InsertDocumentE
P14SfxObjectShell+0x8a5)[0xb782776d]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb780aa8c]
/usr/lib/openoffice/program/../basis-link/program/libfwkli.so[0xb343b87a]
/usr/lib/openoffice/program/../basis-link/program/libfwkli.so[0xb343c217]
/usr/lib/openoffice/program/../basis-link/program/libfwkli.so[0xb3436474]
/usr/lib/openoffice/program/../basis-link/program/libfwkli.so[0xb3436776]
/usr/lib/openoffice/program/../basis-link/program/libcomphelp4gcc3.so(_ZN10comphelper19Synchron
ousDispatch8dispatchERKN3com3sun4star3uno9ReferenceINS4_10XInterfaceEEERKN3rtl8OUStringESD_lRKN
S4_8SequenceINS3_5beans13PropertyValueEEE+0x27d)[0xb7a95031]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb771b81d]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb78383b9]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZN13SfxDispatcher7ExecuteEtttRK1
0SfxItemSet+0x109)[0xb7838c87]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so(_ZN13SfxDispatcher7ExecuteEttRK10
SfxItemSet+0x29)[0xb7838d2f]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb7719c56]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb7838706]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb7854713]
/usr/lib/openoffice/program/../basis-link/program/libsfxli.so[0xb78546c9]
/usr/lib/openoffice/program/../basis-link/program/libvclli.so[0xb6e74788]
/usr/lib/openoffice/basis3.0/program/libvclplug_genli.so(_ZN10SalDisplay21DispatchInternalEvent                 Ev+0x9f)[0xb51e7203]
/usr/lib/openoffice/basis3.0/program/libvclplug_gtkli.so[0xb55c605e]
/usr/lib/libglib-2.0.so.0[0xb5807b65]
/usr/lib/openoffice/basis3.0/program/libvclplug_genli.so(_ZN14X11SalInstance5YieldEbb+0x2f)[0xb                 51edc3f]
/usr/lib/openoffice/program/../basis-link/program/libvclli.so(_ZN11Application5YieldEb+0x57)[0x                 b6cfc88b]
/usr/lib/openoffice/program/../basis-link/program/libvclli.so(_ZN11Application7ExecuteEv+0x2b)[                 0xb6cfc8d9]
/usr/lib/openoffice/program/../basis-link/program/libsofficeapp.so[0xb7dcd6fe]
/usr/lib/openoffice/program/../basis-link/program/libvclli.so[0xb6cffe41]
/usr/lib/openoffice/program/../basis-link/program/libvclli.so(_Z6SVMainv+0x2c)[0xb6cfffdd]
/usr/lib/openoffice/program/../basis-link/program/libsofficeapp.so(soffice_main+0xd0)[0xb7ded94                 c]
/usr/lib/openoffice/program/soffice.bin(main+0x20)[0x8048c34]
/lib/libc.so.6(__libc_start_main+0xd0)[0xb7b7c3f0]
/usr/lib/openoffice/program/soffice.bin(__gxx_personality_v0+0xad)[0x8048b61]
not sure what else will be useful, but let me know as i need a way to edit a .doc file rather desperately.
Cheers!
Re: Openoffice 2.4 and 3.0.0-r1 crash on startup
Post by wolfden » Tue Jan 13, 2009 4:16
so you are mixing portage and entropy?
mordjah
Post by mordjah » Tue Jan 13, 2009 4:47
nope thats the output from "equo install glibc"
this system was originally sabayon 1x but was fully updated to 3.5
