Java support in OpenOffice
Oban
Post by Oban » Fri Jan 02, 2009 17:04
I am using Sabayon 4 on AMD64 and OpenOffice 3.0
The options dialog/ java section does not show any runtime environment that can be selected. (Use a Java runtime environment is checked)
Java works from the command line and in browser(plugins).
When trying to add a jre, none of the folders /usr/lib/jvm/sun-jdk-1.6.0.11/jre, /opt/sun-jdk-1.6.0.11/jre/ or /opt/sun-jdk-1.6.0.11/ are accepted. I have the same result with the installed icedtea folders.
Any suggestions?
benvdh
Re: Java support in OpenOffice
Post by benvdh » Mon Jan 05, 2009 23:46
I'm having the exact same problem here with sabayon 4.0 although I'm not on 64-bit.
I've already tried removing my local openoffice profile since that is where javavendors.xml file resides. But doesn't seem to work. This bug in ubuntu seems to be related to this problem:
https://bugs.launchpad.net/ubuntu/+sour ... +bug/96875
Also when I run soffice.bin from the commandline I get the following errors when trying to select a jre through Tools > Options > Java:
(soffice:9110): Gtk-WARNING **: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
[Java framework] Invalid value for bootstrap variable: UNO_JAVA_JFW_VENDOR_SETTINGS[Java framework] Invalid value for bootstrap variable: UNO_JAVA_JFW_VENDOR_SETTINGS
Another problem I run into is that when I try to run presenter it hangs and when I try to close it, it gives the attached output. I think it's related to the fact that there is no JRE available, although I'm not sure.
Regards,
Ben
Post by Fitzcarraldo » Tue Jan 06, 2009 0:40
Have you checked the Gentoo Forums? The last post in the following thread points to a couple of other threads with fixes. As SL is essentially Gentoo, those posts may help you.
http://forums.gentoo.org/viewtopic-t-656831.html
