ark crashing [Solved]
Postby dunsurfin » Sun Dec 28, 2008 19:38
Sabayon 4 x86-64 fresh install using KDE 3.5.10
ark crashes when opened from the menu or when right clicking on an archive and selecting extract but opens successfully from konsole.
backtrace and excerpt from xsession errors below.
dunsurfin
Re: ark crashing
Postby E.M.G. » Tue Dec 30, 2008 17:27
I'm getting the same thing ... I've tried re-installing ark but that didn't work ... so if you find a solution ..please post back
E.M.G.
Re: ark crashing
Postby colejv » Wed Dec 31, 2008 19:32
Same issue, my logs look the same as those posted above
If I actually open a file from konsole (ark /path/to/file) the following warnings are shown but it works.
kio (KMimeType): WARNING: mimetype not valid '' (missing entry in the file ?)
kparts: WARNING: StatusBarExtension::removeStatusBarItem. Widget not found : [KPushButton pointer (0x7c9e30) to widget CancelButton, geometry=100x30+0+0]
Sabayon 4 x86-64 KDE 3.5.10
colejv
Re: ark crashing
Postby DHalens » Thu Jan 01, 2009 1:14
Same issue here.
Also, right click on a file and "previsualize in ark" gives an error /usr/kde/3.5/lib64/kde3/libarkpart.so: undefined symbol: stat64
DHalens
Re: ark crashing
Postby dunsurfin » Thu Jan 01, 2009 9:11
I now have a working ark by doing:
equo install ark
and then:
equo remove ark-3.5.10 --nodeps
and pointing the menu to usr/kde/4.1/bin/ark
Perhaps someone more advanced can point me in the right direction for adding just that item to my path and also restoring the right click option for that entry on a compressed file in konqueror.
dunsurfin
Re: ark crashing
Postby colejv » Sun Jan 04, 2009 2:56
I tried emerging ark (hoping rebuilding a dependency would help) it did not.
colejv
Ark crashes
Postby wilson.meier » Mon Jan 05, 2009 15:13
ark is always crashing if it's started from kde context menu.
Here the traceback:
[KCrash handler]
#5  0x00007fc99e585535 in raise () from /lib/libc.so.6
#6  0x00007fc99e5869e0 in abort () from /lib/libc.so.6
#7  0x00007fc9a4361687 in ?? () from /usr/kde/3.5/lib64/libkdecore.so.4
#8  0x00007fc9a4361855 in kdbgstream::flush ()
#9  0x00007fc999952f48 in ?? () from /usr/kde/3.5/lib64/libkdeinit_ark.so
#10 0x00007fc999952f62 in ?? () from /usr/kde/3.5/lib64/libkdeinit_ark.so
#11 0x00007fc999952952 in ?? () from /usr/kde/3.5/lib64/libkdeinit_ark.so
#12 0x00007fc9999502f5 in ?? () from /usr/kde/3.5/lib64/libkdeinit_ark.so
#13 0x00007fc9a43bfece in KUniqueApplication::processDelayed ()
#14 0x00007fc9a43bfff0 in KUniqueApplication::qt_invoke ()
#15 0x00007fc9a2ee4e5c in QObject::activate_signal ()
   from /usr/qt/3/lib64/libqt-mt.so.3
#16 0x00007fc9a31cac32 in QSignal::signal ()
#17 0x00007fc9a2efd20d in QSignal::activate ()
#18 0x00007fc9a2f03748 in QSingleShotTimer::event ()
#19 0x00007fc9a2e8e5fd in QApplication::internalNotify ()
#20 0x00007fc9a2e8f318 in QApplication::notify ()
#21 0x00007fc9a435efe4 in KApplication::notify ()
#22 0x00007fc9a2e84cfb in QEventLoop::activateTimers ()
#23 0x00007fc9a2e45de7 in QEventLoop::processEvents ()
#24 0x00007fc9a2ea2ea3 in QEventLoop::enterLoop ()
#25 0x00007fc9a2ea2d52 in QEventLoop::exec ()
#26 0x00007fc99994facd in kdemain () from /usr/kde/3.5/lib64/libkdeinit_ark.so
#27 0x0000000000406601 in ?? ()
#28 0x0000000000406d5f in ?? ()
#29 0x00000000004072b5 in ?? ()
#30 0x00000000004080f0 in ?? ()
#31 0x00007fc99e5724a4 in __libc_start_main () from /lib/libc.so.6
#32 0x00000000004047f9 in ?? ()
#33 0x00007fffad977318 in ?? ()
#34 0x0000000000000000 in ?? ()
Any suggestions?
Greets wilson
EDIT: Please remove this post.
wilson.meier
Re: Ark crashes if started from contextmenu
Postby MaxP90 » Mon Jan 05, 2009 15:50
a lot of people have this problem (me too)
viewtopic.php?f=59&t=15538
MaxP90
Re: ark crashing
Postby wolfden » Tue Jan 06, 2009 4:13
merged
Re: ark crashing
Postby joost » Tue Jan 06, 2009 16:49
So its ark for kde 3.5.10 on sabayon x86_64 that is broken?
