Recover erased data, please help! [Solved]
AlmaFuerte
Post by AlmaFuerte » Sat Dec 27, 2008 23:15
Hi everyone. I've a big problem. When i try to delete the contents of a directory, i make a mistake and i delete the contents of a directory with a lot of important information. The files in that directory were simple files, like pdf, tex, odt and so. The fs is ext3.
Can i recover the erased files????
Thanks a lot!!!!
Imagination is more important than knowledge. Albert Einstein.
Re: Recover erased data, please help!!!
Post by joost » Sat Dec 27, 2008 23:23
AlmaFuerte
Post by AlmaFuerte » Tue Dec 30, 2008 23:12
Well, i can solve (at least partially) the problem. I've used a software tool called testdisk (http://www.cgsecurity.org).
This tool is not installed by default, so in first place
#emerge app-admin/testdisk
Later, we can use the tool basically in this way
#photorec -d /source_dir /dest_dir
where source_dir is the directory that we want to recover, and dest_dir is the directory where the tool will place the recover data.
With this tool i could recover a lot of information: 40182 files, including pdf, tex, jpg, odt, ods, png, etc...
I hope this can help somebody...
