NFS mounting
psilo357
NFS mounting
Post by psilo357 » Tue Dec 23, 2008 2:28
I have a share on my freenas server that contains all of my music that i would like to mount, however, when i attempt to mount it I am getting an error, here is the command I am using to mount:
# mount -t nfs 192.168.1.115:/mnt/Music/Music /media/music
Which should work just fine, but everytime i run it, it takes about a minute then just outputs the following:
mount.nfs: internal error
any ideas?
EDIT: seem it is probably due to the portmap service not running, how would i go about starting this in sabayon? sorry for all the questions, am new to sabayon and somewhat new to linux. Also, if i wanted to add portmap to startup during boot, how would i do so? I am interested because i would like to mount this drive on boot every time as well, and can make the fstab entries, but would need it running of course.
EDIT2: guess im too fast to ask questions, sorry for wasting a post on the forums, but this was a great walkthrough and worked perfectly.
http://beans.seartipy.com/2006/04/13/a- ... on-gentoo/
One question though I would love answered, does sabayon use the exact same system as gentoo, so using the command
rc-update add portmap default
adds it to boot sequence? I used the command and it said added, but im not sure if sabayon uses the same setup.
thanks
Re: NFS mounting
Post by wolfden » Tue Dec 23, 2008 6:14
sabayon is gentoo so what works for gentoo works here
