Removing Real Player dependency for MPlayer [Solved]
Postby micia » Sun Dec 14, 2008 20:15
I would like to install MPlayer for video playback, but I noticed
that it forces me to install Real Player (which I particularly hate by the way).
Since it seems useless to me having 2 players that do almost the same things and
that I would like to avoid being bound to the Real Player license for using an open source software
like MPlayer; Could someone tell me if it is possible to remove this dependency in some way
or if my only possibility is to do it in the dirty way
equo install mplayer --nodeps
Thanks in advance for any help :D
micia
Re: Removing Real Player dependency for MPlayer
Postby wolfden » Sun Dec 14, 2008 21:15
equo is binary so no you can't
you will need to use portage to use USE flags
Postby micia » Sun Dec 14, 2008 22:11
I guess I may try, thank you for the quick answer;
It could maybe a good idea to add a "mini" version of mplayer in equo :)
I was waiting for a good reason to try portage, anyway...
micia
Postby wolfden » Sun Dec 14, 2008 22:14
Postby lxnay » Sun Dec 14, 2008 23:56
Real Player is now masked and its USE flag removed globally.
We already applied this upstream rule to the Entropy branch 4
Follow me on Twitter
Add me on Facebook
Add me on Google+
lxnay
Land Owner
Postby micia » Mon Dec 15, 2008 0:05
Thank you for your help,
I guess I will just wait for the release of Sabayon 4!
I am waiting for the 4 version more and more :D
keep up with your excellent work.
micia
