K3b doesn't start
soloingbastard
K3b doesn't start
Post by soloingbastard » Sun Dec 07, 2008 23:34
Hey, just relatively recently installed Sabayon 3.5.1 and i've found rather disturbingly that K3B doesn't even open. When i open it, it never even gets to the detecting drives part.
What could this be? any ideas on how to fix this?
thnx
Re: K3b doesn't start
Post by wolfden » Mon Dec 08, 2008 3:49
what is the error?
did u start it from terminal to see the errors?
no errors/logs - no idea
Thev00d00
Generally Awesome (tm)
Post by Thev00d00 » Tue Dec 09, 2008 14:35
this happens to me also, it does start, just takes half and hour! no joke
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
thenthenio
Post by thenthenio » Tue Dec 09, 2008 18:06
Try to run it from a Konsole as normal user and see what is the output on the konsole itself.
Mine prints this:
$ k3b
$ kdecore (KAction): WARNING: KActionCollection::KActionCollection( QObject *parent, const char *name, KInstance *instance )
(K3bDevice::HalConnection) initializing HAL >= 0.5
Mapping udi /org/freedesktop/Hal/devices/storage_model_DVD_RAM_UJ_861H to device /dev/sr0
/dev/sr0 resolved to /dev/sr0
/dev/sr0 is block device (0)
/dev/sr0 seems to be cdrom
bus: 3, id: 0, lun: 0
(K3bDevice::Device) /dev/sr0: init()
(K3bDevice::Device) /dev/sr0 feature: CD Mastering
(K3bDevice::Device) /dev/sr0 feature: CD Track At Once
(K3bDevice::Device) /dev/sr0 feature: CD-RW Media Write Support
(K3bDevice::Device) /dev/sr0 feature: DVD Read (MMC5)
(K3bDevice::Device) /dev/sr0 feature: DVD+R
(K3bDevice::Device) /dev/sr0 feature: DVD+RW
(K3bDevice::Device) /dev/sr0 feature: DVD+R Double Layer
(K3bDevice::Device) /dev/sr0 feature: DVD-R/-RW Write
(K3bDevice::Device) /dev/sr0 feature: Rigid Restricted Overwrite
(K3bDevice::Device) /dev/sr0 feature: Layer Jump Recording
(K3bDevice::Device) /dev/sr0 unknown profile: 2
(K3bDevice::Device) /dev/sr0: dataLen: 60
(K3bDevice::Device) /dev/sr0: checking for TAO
(K3bDevice::Device) /dev/sr0: checking for SAO
(K3bDevice::Device) /dev/sr0: checking for SAO_R96P
(K3bDevice::ScsiCommand) failed:
command: MODE SELECT (55)
errorcode: 70
sense key: ILLEGAL REQUEST (5)
asc: 26
ascq: 0
(K3bDevice::Device) /dev/sr0: checking for SAO_R96R
errorcode: 70
asc: 26
ascq: 0
(K3bDevice::Device) /dev/sr0: checking for RAW_R16
errorcode: 70
asc: 26
ascq: 0
(K3bDevice::Device) /dev/sr0: checking for RAW_R96P
errorcode: 70
asc: 26
ascq: 0
(K3bDevice::Device) /dev/sr0: checking for RAW_R96R
errorcode: 70
asc: 26
ascq: 0
(K3bDevice::Device) /dev/sr0: GET PERFORMANCE dataLen = 104
(K3bDevice::Device) /dev/sr0: GET PERFORMANCE successful with reported length: 100
(K3bDevice::Device) /dev/sr0: Number of supported write speeds via GET PERFORMANCE: 6
(K3bDevice::Device) /dev/sr0 : 11080 KB/s
(K3bDevice::Device) /dev/sr0 : 8310 KB/s
(K3bDevice::Device) /dev/sr0 : 5540 KB/s
(K3bDevice::Device) /dev/sr0 : 2770 KB/s
(K3bDevice::Device) /dev/sr0 : 1385 KB/s
(K3bDevice::DeviceManager) setting current write speed of device /dev/sr0 to 11080
(K3bDevice::DeviceManager) dev /dev/sr0 already found
(K3bDevice::DeviceManager) found config entry for devicetype: MATSHITA DVD-RAM UJ-861H
Devices:
Blockdevice: /dev/sr0
Generic device:
Vendor: MATSHITA
Description: DVD-RAM UJ-861H
Version: 1.50
Write speed: 4234
Profiles: DVD-ROM, DVD-R sequenziale, DVD-R sequenziale a doppio strato, DVD-R jump a doppio strato, DVD-RAM, DVD-RW a riscrittura limitata, DVD-RW sequenziale, DVD+RW, DVD+R, DVD+R a doppio strato, CD-ROM, CD-R, CD-RW
Read Cap: DVD-ROM, DVD-R, DVD-R sequenziale, DVD-R a doppio strato, DVD-R sequenziale a doppio strato, DVD-R jump a doppio strato, DVD-RW, DVD-RW a riscrittura limitata, DVD-RW sequenziale, DVD+RW, DVD+R, DVD+RW a doppio strato, DVD+R a doppio strato, CD-ROM, CD-R, CD-RW
Write Cap: DVD-R, DVD-R sequenziale, DVD-R a doppio strato, DVD-R sequenziale a doppio strato, DVD-R jump a doppio strato, DVD-RW, DVD-RW a riscrittura limitata, DVD-RW sequenziale, DVD+RW, DVD+R, DVD+R a doppio strato, CD-R, CD-RW
Writing modes: SAO, TAO, Riscrittura limitata, Livello Jump
Reader aliases: /dev/sr0
kdecore (KAction): WARNING: KActionCollection::operator+=(): function is severely deprecated.
QMultiInputContext::changeInputMethod(): index=0, slave=xim
It lists some feature, supported writing speeds, supported media types...
Cheers.
Mauro
soloingbastard
Post by soloingbastard » Tue Dec 09, 2008 18:11
All i get is this
no error lines, no hang ups nothing, just doesn't seem to continue
[email protected] ~ $ k3b
Xlib:  extension "XInputExtension" missing on display ":1.0".
Failed to get list of devices
[email protected] ~ $ kdecore (KAction): WARNING: KActionCollection::KActionCollection( QObject *parent, const char *name, KInstance *instance )
Mapping udi /org/freedesktop/Hal/devices/storage_model_DVD_ROM_SH_D162C to device /dev/sr1
Mapping udi /org/freedesktop/Hal/devices/storage_model_CD/DVDW_SH_S182D to device /dev/sr0
thenthenio
Post by thenthenio » Wed Dec 10, 2008 10:09
One error is here:
Looks like /dev/sr0 is pointing to nothing.
I don't know what this means.
Probably it could be interesting to have a look to dmesg output and to /proc/scsi dir.
In my case I have the /proc/scsi/scsi file that contains:
# cat /proc/scsi/scsi
Attached devices:
Host: scsi0 Channel: 00 Id: 00 Lun: 00
Vendor: ATA Model: WDC WD2500BEKT-0 Rev: 11.0
Type: Direct-Access ANSI SCSI revision: 05
Host: scsi3 Channel: 00 Id: 00 Lun: 00
Vendor: MATSHITA Model: DVD-RAM UJ-861H Rev: 1.50
Type: CD-ROM ANSI SCSI revision: 05
I think now you need some kernel guru to help you...
Good luck.
Mauro
