Kernel make menuconfig fails
Postby kerrgi » Fri Nov 14, 2008 22:23
Hello, I'm trying to compile a custom kernel from the kernel.org sources, and when I run make menuconfig it fails bring up the errors found here: http://rafb.net/p/Vv5qXw50.html.
I suspect it may be from missing kernel-headers, but there is no kernel-headers file in equo. Anyone know what is most likely the issue here?
Please note: I'm only using kernel.org sources because my hardware needs the latest drivers; make menuconfig fails with the sabayon kernel sources too.
Thanks in advance,
Greg
kerrgi
Re: Kernel make menuconfig fails
Postby wolfden » Fri Nov 14, 2008 22:49
there is a lot of kernel sources in portage already - why not give them a whirl - can go all the way up to .28 even
Postby kerrgi » Fri Nov 14, 2008 23:17
Right but what I'm saying is that they still don't build.
make menuconfig doesn't work any of the sources
kerrgi
