Eclipse 3.4 Not working
vwerner
Post by vwerner » Fri Oct 17, 2008 12:13
Hi All,
I've tried to get eclipse 3.4 to run but without any success:
1) I've tried to install through spritz by selecting the packet eclipse-sdk-3.4 and letting it do all the work of finding the dependencies. It looks like the install is succesfull but when you try to execute it you get an error initializing the software complaining about many classes not found (osg equinox). I've downloaded the clases and added them to /var/lib/eclipse-3.4 but it didn't work either.e environ
2) I've tried to do it following the instructions found on the gentoo wiki: I get the same result.
3) I've purged the system from all eclipse packages and configurations and tried to download it from yoxos.com so I get the exact configuration I want. It runs but dosn't recognize any of the plugins I've added.
Any one has a clear way to get it to work?
Thanks!
CatalanUser
Re: Eclipse 3.4 Not working
Post by CatalanUser » Fri Oct 17, 2008 12:39
Hi vwerner,
The Eclipse 3.4 package is broken at the moment, so it won't work. However, joost gave us a solution: you can download it from the eclipse website and install it. I've done so and it works without any issues.
xlnagla
Post by xlnagla » Sat Oct 18, 2008 4:10
as a second note, you may have to specify a -vm argument when running eclipse depending on the state of your java.
example:
./eclpise -vm /opt/sun-jdk-1.6.0.07/bin
~xlnagla
