Openoffice 3 install
Postby carra » Tue Oct 14, 2008 10:43
Hi there,
how to install Openoffice 3?
I updated my Sabayon 3.5 box but I can't see the new Openoffice major release.
Should I build it from source through Portage?
Thanks in advance for helping.
carra from Italy
Phenom II X2 555 BE felicemente sbloccato a [email protected] | Asrock 890GM Pro3 | Corsair CX series 430W | Corsair A50 | Kingston 2x2GB HyperX+G.Skill ECO 2x2GB (courtesy of Jospeh) | SSD 64GB Kingston Now V100 | WD 1,5TB | WD 1TB SATA6 64MB Black
carra
Re: Openoffice 3 install
Postby chsims1 » Tue Oct 14, 2008 10:47
That's your choice carra :). Note that the package will need to be unmasked and that there is also a binary version available.
chsims1
Postby albfneto » Tue Oct 14, 2008 20:40
Compile OpenOffice is very lon timing. is more easy to use the binary.
Postby WarraWarra » Tue Oct 14, 2008 21:45
Once it is in portage tree / emerge of gentoo then it should be on the way for us into equo as bin package.
But using emerge and a few hours you should be able to build it yourself if you do not wish to wait.
http://gentoo-portage.com/app-office/openoffice
http://go-oo.org/download/
http://download.go-oo.org/OOO300/ooo-bu ... 0.6.tar.gz
WarraWarra
Postby albfneto » Tue Oct 14, 2008 23:54
Procedure for installation of OpenOffice easily, binary and via portage:
Log as root with>
su and password
remove the old OpenOffice:
emerge -C openoffice
update Portage:
emerge --sync
emerge -av portage
update dependencies:
emerge -va python && python-updater
if NOT want binary openoffice: (compilation, many yours!)
LINGUAS="cc" emerge -va openoffice SUBSTITUTE "cc" FOR YOUR LANGUAGE CODE, AS FOR EXAMPLE, "en"
If you will use the pre compiled OpenOffice, use this command:
LANGUAGE="XX" emerge -av openoffice-bin SUBSTITUTE "XX" FOR YOUR COUNTRY NUMERIC CODE, EXAMPLE: "55" FOR BRAZIL
Postby madcow983 » Thu Nov 20, 2008 15:55
i can still use the 2.4 version...
but just for curiosity: how long do i have to wait to find openoffice3 available in equo?
:wink:
madcow983
Postby Fitzcarraldo » Thu Nov 20, 2008 18:02
albfneto wrote:if NOT want binary openoffice: (compilation, many yours!)
Actually, you had better look in the ebuild file. For example, the openoffice-bin-3.0.0.ebuild file looks for the LINGUAS environment variable, and I had to do:
emerge -C openoffice openoffice-l10n-en_GB-2.4.1
LINGUAS="en_GB" emerge -1v =openoffice-bin-3.0.0
so presumably you would have to do:
emerge -C openoffice openoffice-l10n-pt-2.4.1
LINGUAS="pt_BR" emerge -1v =openoffice-bin-3.0.0
EDIT: By the way, there was a bug in the ebuild for 3.0.0 that means the dictionaries do not get installed without some manual intervention -- see Gentoo Bugzilla bug report 242312:
http://bugs.gentoo.org/show_bug.cgi?id=242312
Postby joost » Fri Nov 21, 2008 10:57
Sabayon 4.
@Fitzcarraldo
You might not noticed this, but we have our own OpenOffice ebuild. We splitted the languages in seperate packages.
http://svn.sabayonlinux.org/listing.php ... pp-office_
Postby Fitzcarraldo » Fri Nov 21, 2008 12:00
joost wrote:@Fitzcarraldo
According to:
http://svn.sabayonlinux.org/filedetails ... %2FReasons
these localised OOo ebuilds are for the source version of OOo 3.0.0 only, not the pre-compiled (bin) version, so I assume they would take several hours to compile (the last time I built openoffice it took around six hours). So I'll stick to emerging openoffice-bin. But thanks for pointing it out, as I hadn't noticed.
