Opera freezes on some sites [Solved]
Postby LordBernhard » Sat Sep 27, 2008 21:44
Hey!
I'm having a REALLY grave problem (imo).. Opera lags on some sites while loading (the whole window freezes and doesn't react anymore for like 20 seconds) .. I've tried using firefox (those sites work there) but it's interface is slow in general (compared to opera .. of course this is just subjectiv) .. on other distributions I have no slowdowns on these sites using Opera.
One of those sites which make opera freeze (everytime I open it) is:
http://www.phoronix.com
I'm using Sabayon Linux 3.5, x86, Opera 9.52 Build 2091, Flash player 9.0.124.0 (from entropy)
Hope someone is able to help me.. it's really annoying when you search for something in google and enter such a site which freezes your browser :-(
Best regards
Bernhard
[Edit]: Just started opera from the command line .. that's the output:
ERROR: ld.so: object 'libjvm.so' from LD_PRELOAD cannot be preloaded: ignored.
ERROR: ld.so: object 'libawt.so' from LD_PRELOAD cannot be preloaded: ignored.
opera: X Shared memory extension is not available. ZPixmap not supported
QMultiInputContext::changeInputMethod(): index=0, slave=xim
opera: Plug-in 8493 is not responding. It will be closed.
opera: Define environment variable OPERA_KEEP_BLOCKED_PLUGIN to keep blocked plug-ins.
so.. a plugin seems to block.. any ideas?
output of about:plugins
Shockwave Flashapplication/futuresplash   spl
application/x-shockwave-flash   swf
/opt/opera/lib/opera/plugins/libflashplayer.so
DjVuLibre-3.5.21image/x-djvu   djvu,djv
/usr/lib/nsbrowser/plugins/nsdejavu.so
/usr/lib/nsbrowser/plugins/libflashplayer.so
/opt/netscape/plugins/libflashplayer.so
LordBernhard
Re: Opera freezes on some sites
Postby Thev00d00 » Sat Sep 27, 2008 22:50
Try updating flash?
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
Thev00d00
Generally Awesome (tm)
Postby LordBernhard » Sun Sep 28, 2008 0:30
thanks for your reply :-)
already tried it after I posted... I'm now at the latest available 10.0 RC from portage.. still freezes :-(
LordBernhard
Postby doom0r » Sun Sep 28, 2008 2:30
Your browser is complaining about Java. jvm is Java Virtual Machine and awt is found out to be via google: "libawt.so is a shared lib referenced from the JavaSoft AWT classes
(Toolkit -> MToolkit.java)."
Looking at the page source the only flash i saw was this: http://www.phoronix.net/images/advertis ... 728x90.swf
If you can view that directly in your browser that's one thing knocked off, leaving the only other thing: the whole page is javascript and your browser apparently can't find java.
How to fix that, you'll have to ask someone else, but I took a look and this is what I've found, so I'm just passing the info. :D
doom0r
Postby Thev00d00 » Sun Sep 28, 2008 14:26
You realise javascript is not anything todo with java vm?
Are you on 32 or 64 bit?
twitter: Follow Me
G+: Circle Me
Thev00d00
Postby LordBernhard » Sun Sep 28, 2008 14:46
v00d00 wrote:You realise javascript is not anything todo with java vm?
32bit .. thought I'll have less problems with multimedia/plugins here....
LordBernhard
Postby dunsurfin » Sun Sep 28, 2008 18:58
The site http://www.phoronix.com/ also freezes 64 bit opera here but disabling plugins allows it to load OK. I suppose a way to find out would be to disable each plugin in turn.
dunsurfin
Postby dunsurfin » Sun Sep 28, 2008 23:56
I decided to remove my 64 bit Opera and installed the 32 bit direct from source. Managed to get java going but the freezing was still there for some sites. I found that by changing all the plugin paths to this one /usr/lib32/nsbrowser/plugins seems to have done the trick.
dunsurfin
Postby LordBernhard » Mon Sep 29, 2008 19:19
OMG! You're my hero :D It worked.. For those having the same problem and searching for a solution.. here is it:
In opera:
tools
-- preferences
-- advanced
-- content -- plug-in options.. -- change path ..
uncheck all paths except /usr/lib/nsbrowser/plugins
seems like the multiple entries of plugins have confused opera (I had multiple shockwave flash players in the "detected plugins"- list..
Thanks so much again :-) I finally can go back to opera and use it's gorgeous session management.. it's the only thing I really miss when using konqueror ^^
LordBernhard
Re: Opera freezes on some sites [Solved]
Postby wolfden » Wed Oct 01, 2008 4:36
Edited thread titled to [Solved] as per viewtopic.php?f=57&t=1730
btw did you even look at this:
viewtopic.php?f=59&t=9996&p=59711&
