KDM moved to South Africa [Solved]
dunsurfin
Post by dunsurfin » Thu Sep 25, 2008 9:40
Not sure if this is worth mentioning but after following these 2 threads:
http://www.sabayonlinux.org/forum/viewt ... 53&t=14861
http://www.sabayonlinux.org/forum/viewt ... 76&t=14840
I installed the KDM theme manager and also added the TerminateServer=true to kdmrc. I also downloaded and installed a few KDM themes. Not sure of the exact sequence here but at some point I noticed that my login language had changed to Afrikaans. What changed it I don't know but there in kdmrc was Language=af. I changed it back to en and all is OK again.
PS And I thought the Boer War was over! :)
WarraWarra
Re: KDM moved to South Africa [SOLVED]
Post by WarraWarra » Thu Sep 25, 2008 10:28
LOL that's a good one.
Ja swaar so gebeur die goed .
Yes brother in law / friend / cousin , so happens the stuff .
WOW not even I use afrikaans as defualt language and it's my first language LMAO
Re: KDM moved to South Africa [Solved]
Post by wolfden » Thu Sep 25, 2008 12:16
Post by Fitzcarraldo » Sat Oct 18, 2008 18:45
dunsurfin wrote:Not sure if this is worth mentioning but after following these 2 threads:
Now I'm trying Entropy/Equo/Spritz (only) on a fresh install of SL 3.5 the same thing happened to me. It didn't happen when I made the changes previously while I was using Portage only on my previous installation. I wonder why? :?
sjieke
Post by sjieke » Mon Oct 20, 2008 10:06
My guess is that the kdmrc file isn't protected and got overwritten with some 'strange' defaults... Maybe portage/emerge doesn't overwrite that file, or the defaults are different?
