SIGSEGV on OpenOffice application exit
Postby thenthenio » Tue Sep 23, 2008 15:02
When I exit from any OpenOffice application it causes signal 11 (SIGSEGV).
If I run it from a console shell i get (once I close the application):
$ oocalc
QMultiInputContext::changeInputMethod(): index=0, slave=xim
$ KCrash: Application 'soffice.bin' crashing...
XIO: fatal IO error 9 (Descrittore di file non valido) on X server ":0.0"
after 122 requests (122 known processed) with 0 events remaining.
This happens on both SL 3.5 x86_64 machines i use (a desktop PC and a protable PC).
Everithig works fine, only at exit there is this problem.
Bye.
Mauro
thenthenio
Re: SIGSEGV on OpenOffice application exit
Postby dunsurfin » Tue Sep 23, 2008 17:06
Same here. I just live with it as the crash only happens after OO has closed - there are many posts in other forums about the crashes happening on start up or during operation.
dunsurfin
Postby sjieke » Tue Sep 23, 2008 17:15
I have the exact same error... A solution, cause or direction where to look would be appreciated.
I also run the 64bit dvd version
sjieke
Postby Fitzcarraldo » Thu Oct 23, 2008 23:26
Now that I'm trying out Entropy/Equo/Spritz I'm seeing this problem too on my x86_64 installation and openoffice-2.4.1 from Entropy. It's a pain as the error window pops up at the office every time I close any of the OOo applications, which is frequently as I'm using OOo Writer, Calc and Impress a lot.
It didn't happen to me with the openoffice-bin-2.4.1 and the openoffice-bin-3.0.0 merged from Portage.
Postby sjieke » Fri Oct 24, 2008 8:04
Can we conclude that the problem is only with the openoffice entropy version, or could it be some other library used by openoffice that is causing this?
@Fitzcarraldo: the portage versions you had/have installed, were they on a 3.5 system or on an updated 3.4 system?
sjieke
Postby Fitzcarraldo » Fri Oct 24, 2008 13:02
^On an updated (rolling updates) 3.4f installation, in other words, all the packages and libraries were the latest in Portage, which means several were later versions than those in the Entropy repository.
Postby sjieke » Mon Oct 27, 2008 8:53
Fitzcarraldo,
did you already tried installing openoffice using portage instead of equo in your 3.5 install? I would try it myself but the problem occures on my development machine, and I can't affort to break something... On my other box I don't have the problem, but there I selected as little as possible during installation and only XFCE (it is an old machine with not much processing power). Afterwarts I installed openoffice using equo, but I don't have the crash there...
sjieke
Postby Fitzcarraldo » Mon Oct 27, 2008 11:48
No, I have not tried to install it using Portage rather than Entropy; I also cannot afford to break anything on my laptop as I'm travelling on business most of the time at the moment. I could boot into Windows XP if installing from Portage were to trash OOo and/or SL but I prefer to keep Linux functioning if possible. As soon as SL 4.0 is released I will be reverting to Portage, as Entropy -- good as it is -- does not have all the latest versions and gives me less flexibility than I'm used to. Until then, unless someone finds a solution to this bug or a bug-free 3.0.0 is added to the Entropy repository, I'll put up with the pop-up error message.
Is your other box an x86_64 machine, or an x86 machine? From what I've read on the Web this crash on exit only seems to occur on 64-bit versions. Apparently the Ubuntu folks have fixed it already.
Postby sjieke » Mon Oct 27, 2008 12:45
My other box is a x86 machine, so that probably explains why it doesn't crash there.
sjieke
Postby palemoon » Mon Dec 15, 2008 5:02
Hey did anyone figure this out yet?
I just did a clean install of SL 3.5.1 x86_64 and have the same problem.
palemoon
