amarok and radio on web plugins sometimes works, but...
Post by albfneto » Mon Sep 22, 2008 8:35
Hi
I have Sabayon intsalled in two comps. a Desktop * 64 bits) and a notebook (32 bits)...
In the notebook, all work. i listem radio on web streaming, world and brasil, add radios etc... both in Amaraok as in the plugin of the Firefox Navigator and Opera....
But in the Desktop:
Using Opera browser.... message streaming received, but no sound.....
Using Firefox, message plugin not found.... mplayer ans Xine instsalled.
Amarok works great with their own radios ( shoutcast) but whw a add som elocal or brazilian radio...
No more sound and the message is no multiplexing package found....
If you know the problem, please help...
WarraWarra
Re: amarok and radio on web plugins sometimes works, but...
Post by WarraWarra » Tue Sep 23, 2008 18:46
Try re-installing amarok as maybe their plugnins has some issues and a re-install could fix this ?
Check version on 32bit laptop and compare to 64bit desktop maybe using different versions or missing dependancy's ?
Possible file association problem ?
That should about cover most possible problems it could be.
PS> how is the alsa config on the desktop ? Might want to rerun # alsaconfig / # alsaconf but I doubt it is anywhere close to the problem , not sure.
