hplip bug [Solved]
hplip bug [Solved]
Postby Eldwist » Wed Sep 10, 2008 14:31
Hello to all.
If you enable cups & hplip (I've a HP printer) and you reboot you end up to a console login.
No graph login, nothing, hplip deamon starting error ... that's all.
This is very surprising, HP printers has linux drivers and sabayon should work "out of the box".
I've tested on 3 different PC/laptop, and doesn't matter if you update your system before you'll enable the printer support.
I'm reinstalling right now, and I'll install the latest hplip before doing anything, just to check if it works.
Any idea ?
Regards
Eld
Eldwist
Re: hplip & cups bug
Postby Thev00d00 » Wed Sep 10, 2008 15:31
versions? Hardware?
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
Thev00d00
Generally Awesome (tm)
Postby Eldwist » Wed Sep 10, 2008 16:01
here are some more details :
Printer HP Photosmart C4380
HPLIP : 2.8.5
Software device manager : 14.0
Sabayon 3.5
The printer is connected via WIFI, no problem to discover it and print the test page.
Best Regards
Eld
Eldwist
Postby Eldwist » Wed Sep 10, 2008 18:05
No Way :(
Here is a detailed error message :
starting hpiod
start-stop-daemon: /usr/sbin/hpiod does not exist
starting hpssd
ERROR: hplip failed to start
localhost login:
Eldwist
Re: [SOLVED] hplip & cups bug
Postby Eldwist » Wed Sep 10, 2008 23:25
problem SOLVED,
thanks to snarfer from #sabayon IRC channel who told me that the hplip doesn't use an initscrip anymore, and he told me to remove it from rc-update.
Now the printer works, and the system boot fine.
Thanks
Eld
Eldwist
Re: hplip & cups bug [Solved]
Postby wolfden » Thu Sep 11, 2008 3:34
it's [Solved] at the end per
viewtopic.php?f=57&t=1730
Re: hplip bug [Solved]
Postby jokker » Mon Nov 17, 2008 4:46
How would you "remove" it from rc-update ? I do not understand what to do, thanks
Just found it on my own. For those interested in a real answer:
# rc-update delete hplip
Alienware laptop
Intel Extreme
twin-Nvidia 9800 pci-express 16x SLI
4 GB ram
Raid0 twin sata2 10000rpm drives
Sabayon x86_64, Ubuntu x86_64, XP_64
jokker
