Jack audio server; running as normal user
chsims1
Post by chsims1 » Mon Aug 25, 2008 10:46
Hi All,
I'm having problems getting jackd to start using real time scheduling as a normal user. If I try to start the daemon with:
jackd -R -dalsa
then I get the error:
cannot use real-time scheduling (FIFO at priority 10) [for thread -339331344, from thread -339331344] (1: Operation not permitted)
cannot create engine
The daemon starts fine if I run it as su or omit the realtime option.
After looking on the internet, I have ensured that I am a member of the audio group, and that my /etc/security/limits.conf file contains:
@audio - rtprio 90
@audio - nice -5
@audio - memlock 1000000
but still no success.
Any ideas out there please?
Sabayon Linux 3.5 x86-64
chsims1
Re: Jack audio server; running as normal user
Post by chsims1 » Tue Aug 26, 2008 9:36
Can anyone confirm that they are using Jack with real time scheduling in Sabayon Linux 3.5 as a normal user?
knekke
Post by knekke » Thu Oct 09, 2008 20:42
Did you find a solution??
I have exactly the same problem....
thx
chsims1
Post by chsims1 » Fri Oct 10, 2008 7:38
Sorry, no I didn't. I was just playing really, and didn't persevere. If you find the solution ......... :D
