anyone using amazonmp3?
Postby rashan » Sun Jul 13, 2008 23:21
I'm curious if anyone is using Amazon's mp3 downloader? Particularly if anyone has gotten it working on their x64 Sabayon installations.
I noticed that the Ewwbuntu community repository for Equo has it available for the 32-bit folks, but that's it's only a 32bit repository. (nice to see it though! :) ).
anyone managed to get it working on their 64bit installs, and if so, what did you do to get it working?
rashan
Re: anyone using amazonmp3?
Postby deadfool » Mon Jul 14, 2008 0:53
rashan wrote:I'm curious if anyone is using Amazon's mp3 downloader? Particularly if anyone has gotten it working on their x64 Sabayon installations.
do you want the ebuild? sorry for the 32 bit but i dont have a 64bit processor atm
deadfool
Postby rashan » Mon Jul 14, 2008 2:03
Sure, that'd be great!
rashan
Postby deadfool » Mon Jul 14, 2008 3:56
# Distributed under the terms of the GNU General Public License v2
# be kind, give credit:  initial, Paul Cifarelli <[email protected]>
inherit eutils rpm
MY_PN="amazonmp3"
DESCRIPTION="Amazon mp3 downloader"
HOMEPAGE="http://www.amazon.com/gp/dmusic/help/amd.html?ie=UTF8&forceos=LINUX&ASIN=&isTrack="
SRC_URI="amazonmp3-1.0.3-1.fedora8.i386.rpm"
LICENSE="EUBL"
SLOT="0"
KEYWORDS="-* amd64 x86"
IUSE="X"
RESTRICT="strip test fetch"
RDEPEND="dev-cpp/glibmm dev-cpp/cairomm dev-cpp/gtkmm >=dev-libs/boost-1.34"
pkg_nofetch() {
        einfo "Download the Amazon Downloader manually from Amazon's website at"
        einfo ${HOMEPAGE}
        einfo ""
        einfo "Click \"I agree to the terms of use\" &"
        einfo "Choose the Download now Fedora 8 button"
        einfo ""
        einfo "Then place the file ${SRC_URI}"
        einfo "into ${DISTDIR} and restart the emerge."
pkg_setup() {
        # This is a binary x86 package => ABI=x86
        has_multilib_profile && ABI="x86"
src_unpack() {
        rpm_src_unpack
src_install() {
        mkdir -p ${D}/usr/bin
        cp ${WORKDIR}/usr/bin/amazonmp3 ${D}/usr/bin
        chmod +x ${D}/usr/bin
        mkdir -p ${D}/usr/share/applications
        cp ${WORKDIR}/usr/share/applications/amazonmp3.desktop ${D}/usr/share/applications
        mkdir -p ${D}/usr/share/doc/amazonmp3
        cp ${WORKDIR}/usr/share/doc/amazonmp3/help.html ${D}/usr/share/doc/amazonmp3
        cp ${WORKDIR}/usr/share/doc/amazonmp3/license.html ${D}/usr/share/doc/amazonmp3
        cp ${WORKDIR}/usr/share/doc/amazonmp3/releasenotes ${D}/usr/share/doc/amazonmp3
         mkdir -p ${D}/usr/share/mime-info
        cp ${WORKDIR}/usr/share/mime-info/amazonmp3.keys ${D}/usr/share/mime-info
        cp ${WORKDIR}/usr/share/mime-info/amazonmp3.mime ${D}/usr/share/mime-info
        mkdir -p ${D}/usr/share/mime/packages
        cp ${WORKDIR}/usr/share/mime/packages/amazonmp3.xml     ${D}/usr/share/mime/packages
        mkdir -p ${D}/usr/share/mimelnk/audio
        cp ${WORKDIR}/usr/share/mimelnk/audio/x-amzxml.desktop ${D}/usr/share/mimelnk/audio
        mkdir -p ${D}/usr/share/pixmaps
        cp ${WORKDIR}/usr/share/pixmaps/amazonmp3.png ${D}/usr/share/pixmaps
        cd ${D}/usr/share/applications
        domenu amazonmp3.desktop
        dodir /usr/lib
        cd ${D}/usr/lib
        dosym libssl.so /usr/lib/libssl.so.6
        dosym libcrypto.so /usr/lib/libcrypto.so.6
        dosym libboost_date_time.so /usr/lib/libboost_date_time.so.3
        dosym libboost_signals.so /usr/lib/libboost_signals.so.3
        dosym libboost_iostreams.so /usr/lib/libboost_iostreams.so.3
        dosym libboost_thread-mt.so /usr/lib/libboost_thread-mt.so.3
deadfool
Postby rashan » Mon Jul 14, 2008 5:24
inherit eutils rpm
MY_PN="amazonmp3"
LICENSE="EUBL"
SLOT="0"
IUSE="X"
pkg_nofetch() {
        einfo ${HOMEPAGE}
        einfo ""
        einfo ""
pkg_setup() {
src_unpack() {
        rpm_src_unpack
src_install() {
        dodir /usr/lib
        cd ${D}/usr/lib
Thanks very much. I gave it a quick shot tonight and think I did something wrong. I'll give it another shot tomorrow after I've had some sleep. Did I mention I'm new to this ebuild thing? ;)
For the record, I followed the directions here to setup a local portage overlay. Unfortunately, the example in the wiki downloads and existing ebuild from the bugzilla, so it's not exactly the same situtation I've got going on, and I think that's where I start to go wrong... ;) I created a file (amazonmp3-1.ebuild) in my /usr/local/portage/net-misc/amazonmp3/ directory, and pasted the ebuild from this thread into the empty file. Then, I emerged amazonmp3.
which returns:
localhost rashan # emerge amazonmp3
Calculating dependencies \!!! Manifest file not found: '/usr/local/portage/net-misc/amazonmp3/Manifest'
... done!
!!! All ebuilds that could satisfy "net-misc/amazonmp3" have been masked.
- net-misc/amazonmp3-1 (masked by: corruption)
which probably isnt' quite right... anyways,I'll dig into it more tomorrow and see what I can learn. I appreciate the help,
rashan
Postby deadfool » Mon Jul 14, 2008 6:24
did you do ebuild ebuildname digest? if not it wont work
deadfool
Postby Thev00d00 » Mon Jul 14, 2008 13:39
Added this to x86-64 version to Zenana, feel free to install it from there.
The ebuild needs a bit tinckering to get it to work, you need to change the name of the SRC_URI to SRC_URI="amazonmp3.rpm" (as thats what you get from the amazon downlad site)
EDIT: Getting errors about gtkmm :? Ill see if I can get it sorted
[email protected] ~ $ amazonmp3
amazonmp3: error while loading shared libraries: libgtkmm-2.4.so.1: cannot open shared object file: No such file or directory
EDIT2: Well libgtkmm-2.4.so.1 is there :?:
EDIT3: Well symlinking gives errors about wrong elf type (ie 64bit not 32)
EDIT4: There are no emul-linux (32bit libaries for x86-64) see http://bugs.gentoo.org/show_bug.cgi?id=224747
Sorry, looks like a no go imo
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
Thev00d00
Generally Awesome (tm)
Postby deadfool » Mon Jul 14, 2008 13:51
strange that worked for me of course it was a couple of months ago
deadfool
Postby rashan » Tue Jul 15, 2008 0:35
v00d00 wrote:Added this to x86-64 version to Zenana, feel free to install it from there.
Well, crap. That's too bad.
I suppose that for now, I'll try to get it working on my old x86 Lappy just to play around with...
Thanks to you both for the help. It's not a total loss, I suppose.. I now know more about ebuilds than I ever thought to. ;)
Cheers!
rashan
Postby christo4 » Sat Mar 07, 2009 21:01
Is it still possible to get this for x86 32-bit? I'm new to Sabayon, and can only find the Naendo community repository. Are there others?
christo4
