[ sorry for my bad english ]
Hi All,
Here's my results,
Im using azureus like normal user, and when I trying to download any torrent,
azureus crashes... here's my log...
[ somebody can help me to know what's happends ??
Thank you in advance. ]
[email protected] /usr/bin $ azureus
using /home/richard/.azureus/gentoo.config
$UI not set defaulting to swt
changeLocale: *Default Language* != English (United States). Searching without country..
changeLocale: Searching for language English in *any* country..
changeLocale: no message properties for Locale 'English (United States)' (en_US), using 'English (default)'
(SWT:27511): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to allocate widget with width 250 and height -1
[GUI] SWT update aborted due to previously reported issues regarding its install location
[plug] [Plugin Update] Failed to load plugin details
DEBUG::Fri Mar 07 00:05:07 UTC 2008::org.gudy.azureus2.pluginsimpl.update.PluginUpdatePlugin::checkForUpdateSupport::662
java.lang.Exception: Update check cancelled
at org.gudy.azureus2.pluginsimpl.update.PluginUpdatePlugin.checkForUpdateSupport(PluginUpdatePlugin.java:465)
at org.gudy.azureus2.pluginsimpl.update.PluginUpdatePlugin$4.checkForUpdate(PluginUpdatePlugin.java:192)
at org.gudy.azureus2.pluginsimpl.local.update.UpdateCheckInstanceImpl$1.runSupport(UpdateCheckInstanceImpl.java: 155)
at org.gudy.azureus2.core3.util.AEThread.run(AEThread.java:71)
at org.gudy.azureus2.pluginsimpl.update.PluginUpdatePlugin$5.checkForUpdate(PluginUpdatePlugin.java:286)
[plug] [CoreUpdater] Failed to read primary mirror list
DEBUG::Fri Mar 07 00:05:07 UTC 2008::org.gudy.azureus2.update.CoreUpdateChecker::getPrimaryDownloaders::687:
org.gudy.azureus2.plugins.utils.resourcedownloader.ResourceDownloaderException: Error on connect for 'http://prdownloa ds.sourceforge.net:80/azureus/Azureus3.0.5.0.jar.torrent?download': 403 Forbidden
at org.gudy.azureus2.pluginsimpl.local.utils.resourcedownloader.ResourceDownloaderURLImpl.download(ResourceDownl oaderURLImpl.java:491)
at org.gudy.azureus2.pluginsimpl.local.utils.resourcedownloader.ResourceDownloaderURLImpl$2.run(ResourceDownload erURLImpl.java:349)
at org.gudy.azureus2.core3.util.AEThread2$threadWrapper.run(AEThread2.java:202)
java: xcb_xlib.c:50: xcb_xlib_unlock: Assertion `c->xlib.lock' failed.
Aborted
