How to play APE files in Amarok? [Solved]
ashley194
Post by ashley194 » Sun Sep 30, 2007 14:39
Hi all!
Does anyone here know how to play ape files in Amarok, or is there an different app that does the same thing in SL :?
Thanks 8)
voxiac
Re: How to play APE files in Amarok?
Post by voxiac » Sun Sep 30, 2007 15:36
I wondered about the same thing a while ago... The best solution I could find is a plugin for audacious from gentoo-china overlay.
So:
layman -a gentoo-china
emerge -av audacious-mac
This will also pull commandline tool for ape files (the ebuild is called mac-port but the program itself is just 'mac' IIRC)
I've also heard about a gstreamer plugin for APE codec, but I never tried it.
Also you might want to consider converting your APE files to a more linux-friendly format, e.g. flac or wavpack (I recon both of them can be played with amarok). You won't loose any quality with this feat - they are all lossless after all :). For that purpose you can for example convert APE files to plain WAVs with that 'mac' tool, which you can then encode to flac or wavpack.
ashley194
Post by ashley194 » Sun Sep 30, 2007 18:14
Thanks voxiac, your advice worked like a charm 8)
goodbabywell
Re: How to play APE files in Amarok? [Solved]
Post by goodbabywell » Mon Nov 21, 2011 6:54
i just find an easy solution to Convert and Play APE on Mac/Windows/iTunes/iPod/Winamp/WMP/Andorid and more at http://www.bigasoft.com/articles/conver ... erter.html
svantoviit
Post by svantoviit » Mon Nov 21, 2011 8:35
Converting with ffmpeg* should work too.
ffmpeg -i file.ape file.wav
*Or with avconv now.
If it's an image and a cue-file is provided, you can split the wav-file into tracks with bchunk.
bchunk -w file.wav file.cue result
