codec for audio format 0x162
Postby Stupot » Mon Sep 17, 2007 5:08
I don't have it, I guess. When trying to watch a certain high quality (possibly HD) wmv file, I get an error saying that I don't have the audio codec and no sound plays. I'm pretty sure it's the exact same codec that keeps any sound from playing for either high bandwith versions of Halo Wars http://www.halowars.com/trailer.html .
Any help would be appreciated.
Re: codec for audio format 0x162
Postby Stupot » Tue Sep 18, 2007 16:44
I'm assuming that no one else who has viewed this thread could get this video to play with sound either.
Postby wolfden » Tue Sep 18, 2007 16:52
Postby Stupot » Tue Sep 18, 2007 17:56
Yes, the low quality version has sound for me too, but not the higher quality video. It's not even the HaloWars video that I'm concerned about, but a different high quality video that has no audio for the same reason that it won't play for the high quality HaloWars videos.
Postby wolfden » Tue Sep 18, 2007 19:55
Stupot wrote:I'm assuming that no one else who has viewed this thread could get this video to play with sound either.
I have sound in this too, but it must be a big file as it buffers alot, try using kaffeine - I can't see the difference between the two links myself as far as quality goes.
Postby Stupot » Thu Sep 20, 2007 6:47
After a bit of research, it seems as though this is a problem with AMD 64 bit processors that can be solved by using the 32 bit binary package of mplayer with the win32codec use flag. However, I don't see a win32codec flag, but it's no big deal. I boot into Windows to play some games, so I'll just watch the video there someday.
Postby wolfden » Thu Sep 20, 2007 16:11
USE="gtk quicktime divx gmedia realmedia wmp win32codecs nsplugin firefox xvid" emerge mplayerplug-in
I'm using the 64bit
Postby Fitzcarraldo » Tue Sep 25, 2007 17:54
I can watch the smaller video and hear the audio, but I cannot hear any audio when watching the larger video. I'm using SL x86-64 on an Intel Core 2 Duo T7200.
And I emerged mplayerplug-in manually in exactly the same way as wolfden (as well as also adding afterwards the same local USE flags to /etc/portage/package.use for future compilations).
I also tried the following mplayer commands to see if I could get any debug info. on this problem:
THIS ONE I COULD WATCH AND HEAR:
$ mplayer -afm ffmpeg $HOME/Desktop/HaloWars_ESRB_360p30_ST_1500kbps.wmv
MPlayer SVN-r24130 (C) 2000-2007 MPlayer Team
CPU: Intel(R) Core(TM)2 CPU         T7200  @ 2.00GHz (Family: 6, Model: 15, Stepping: 6)
MMX2 supported but disabled
CPUflags:  MMX: 1 MMX2: 0 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled with runtime CPU detection.
Can't open joystick device /dev/input/js0: No such file or directory
Can't init input joystick
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing /home/fitzcarraldo/Desktop/HaloWars_ESRB_360p30_ST_1500kbps.wmv.
ASF file format detected.
[asfheader] Audio stream found, -aid 1
[asfheader] Video stream found, -vid 2
VIDEO:  [WMV3]  640x360  24bpp  1000.000 fps  1395.0 kbps (170.3 kbyte/s)
Clip info:
 name:
 author:
 copyright:
 comments:
Xlib:  extension "XFree86-VidModeExtension" missing on display ":0.0".
Requested video codec family [wmv9dmo] (vfm=dmo) not available.
Enable it at compilation.
Requested video codec family [wmvdmo] (vfm=dmo) not available.
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffwmv3] vfm: ffmpeg (FFmpeg M$ WMV3/WMV9)
Trying to force audio codec driver family ffmpeg...
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 48000 Hz, 2 ch, s16le, 96.0 kbit/6.25% (ratio: 12000->192000)
Selected audio codec: [ffwmav2] afm: ffmpeg (DivX audio v2 (FFmpeg))
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback...
VDec: vo config request - 640 x 360 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO: [xv] 640x360 => 640x360 Planar YV12
A: 107.6 V: 107.6 A-V:  0.001 ct: -0.043 2803/2803 17%  1%  0.8% 0 0
Exiting... (End of file)
THIS ONE I COULD ONLY WATCH:
$ mplayer -afm ffmpeg $HOME/Desktop/HaloWars_ESRB_720p30_ST_8Mbps.wmv
Playing /home/fitzcarraldo/Desktop/HaloWars_ESRB_720p30_ST_8Mbps.wmv.
VIDEO:  [WMV3]  1280x720  24bpp  1000.000 fps  8000.0 kbps (976.6 kbyte/s)
[wmv3 @ 0xde1e20]Extra data: 8 bits left, value: 0
Requested audio codec family [wma9dmo] (afm=dmo) not available.
Requested audio codec family [wmadmo] (afm=dmo) not available.
Cannot find codec for audio format 0x162.
Read DOCS/HTML/en/codecs.html!
Audio: no sound
VDec: vo config request - 1280 x 720 (preferred colorspace: Planar YV12)
VO: [xv] 1280x720 => 1280x720 Planar YV12
V: 104.6 2896/2896 39%  2%  0.0% 0 0
I've tried running mplayer with "win32codecs" and "mp3lib" instead of "ffmpeg" but no dice. So I cannot find a way of playing 0x162-encoded audio either. Notice that the debug info above says that the codec for 0x162 is required and the codec "family" wma9dmo and wmadmo is required. There is no such codec or codec "family" for Gentoo, is there?
Postby wolfden » Tue Sep 25, 2007 22:36
try it with kaffeine?
Postby Stupot » Wed Sep 26, 2007 3:41
I also re-emerged mplayerplug-in just as wolfden described and it did not fix my sound issue. Kaffeine was no better.
