Error: Load Kernel Modules [Solved]
Discussion for all VM - Installing, Software, Problems
deusr
Post by deusr » Wed Jul 30, 2014 0:41
Anyone know what this is? Strange that my VirtualBox is working very well!
systemd-modules-load.service - Load Kernel Modules
   Loaded: loaded (/usr/lib64/systemd/system/systemd-modules-load.service; static)
   Active: failed (Result: exit-code) since Ter 2014-07-29 20:31:42 BRT; 9min ago
     Docs: man:systemd-modules-load.service(8)
           man:modules-load.d(5)
  Process: 1476 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 1476 (code=exited, status=1/FAILURE)
Jul 29 20:31:42 neit systemd-modules-load[1476]: Inserted module 'vboxnetflt'
Jul 29 20:31:42 neit systemd-modules-load[1476]: Inserted module 'vboxnetadp'
Jul 29 20:31:42 neit systemd[1]: systemd-modules-load.service: main process exited, code=exited, status=1/FAILURE
Jul 29 20:31:42 neit systemd[1]: Failed to start Load Kernel Modules.
Jul 29 20:31:42 neit systemd[1]: Unit systemd-modules-load.service entered failed state.
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Hint: Some lines were ellipsized, use -l to show in full.
belcocco
Re: Error: Load Kernel Modules
Post by belcocco » Wed Jul 30, 2014 16:13
msdobrescu
Post by msdobrescu » Fri Mar 27, 2015 19:54
I have that too, I'm still trying to find the reason...
Post by Fitzcarraldo » Fri Mar 27, 2015 23:47
Is it the same problem as reported in the post Vbox errors after update? If it is, try the fix suggested by linuxfluesterer .
msdobrescu
Post by msdobrescu » Sat Mar 28, 2015 6:55
I have just managed to find the reason, is ZFS. It seems to be dropped from the kernel, but left configured to load it. IMHO, should have been left there or removed the configuration for it.
