GRUB menu [Solved]
moldmaker
GRUB menu [Solved]
Post by moldmaker » Sat Oct 21, 2017 8:57
After the last system update, the GRUB menu list is reduced to only Sabayon. Before, it listed all installed OS on the computer (one more Linux and two Windows installations).
How can I get the entries back?
Edit: I already tried
grub-mkconfig -o /boot/grub/grub.cfg
and it worked just fine, but the menu items for the other OS are still missing.
Mm.
Re: GRUB menu
Post by sabayonino » Sat Oct 21, 2017 11:09
is sys-boot/os-prober package installed ?
moldmaker
Re: GRUB menu
Post by moldmaker » Sat Oct 21, 2017 13:16
Yes, it is installed (and has been before).
Mm.
moldmaker
Re: GRUB menu
Post by moldmaker » Sat Oct 21, 2017 14:56
I solved the problem now by extracting the grub.cfg from an older partition image I made some weeks ago. Then I copied it to the correct location in /boot/grub. Now the menu is complete again.
Still a little confused because this did not happen with earlier system updates/upgrades. However, I marked the thread as solved.
Mm.
ypell
Re: GRUB menu [Solved]
Post by ypell » Sat Oct 21, 2017 17:39
Hi there, I have the same problem. I lost the Windows menu entry after upgrading my kernel. For some reason, os-prober and grub2-mkconfig don't seem to offer a solution. Unfortunately, I do not have the benefit of an old grub.cfg laying around. Any suggestions? Thanks.
ypell
Post by ypell » Sun Oct 22, 2017 0:37
Alright. Following up on my own post.
Among several google searches I found something that worked. I mounted the Windows boot partition, /dev/sda1 in my case, as in:
# mount /dev/sda1 /media
And then os-prober found the Windows OS. After that, grub2-mkconfig worked and generated a menu item for Windows.
moldmaker
Post by moldmaker » Sun Oct 22, 2017 8:45
Ok thanks and good to know, better than my solution ....
Mm.
Post by sabayonino » Thu Oct 26, 2017 12:16
there is a bug for os-prober
https://bugs.gentoo.org/607518#c11
here https://bugs.gentoo.org/607518#c13 1.74 version works and 1.76 fails
msdobrescu
Post by msdobrescu » Sun Oct 29, 2017 21:47
Same here, but for MBR only, for UEFI works.
