Anyone uses XBMC
Re: Anyone uses XBMC
Post by sabayonino » Sat Aug 12, 2017 11:01
Hi
XBMC is no longer mantained, SL has KODI in its repositories, just install
# equo i kodi
:roll:
Uzi
Post by Uzi » Sun Aug 13, 2017 0:04
It's not been called XBMC for a long time. Now called KODI but it is the same thing. I have used it for a long time to manage my movies & TV shows. For that I give it 10/10. Many use it for streaming, I use it to stream some tv shows but it depends a lot on the source, their servers & your d.l. speed or you get lots of buffering. I also have it in the bedroom loaded on a Raspberry Pi in its OPENELEC version.
Youtube has loads of good instruction vids but again search KODI not XBMC.
Post by albfneto » Thu Aug 17, 2017 21:23
bookewyrmm
Post by bookewyrmm » Mon Nov 27, 2017 15:38
there is also a R-Pi Sabayon image that runs kodi very well.
Look for it listed in the download mirror closest to you
Sabayon_Linux_16.06_armv7l_RPi_MediaCenter_8GB.img.xz
