automount diskdrive [Solved]
woody3883
Post by woody3883 » Wed May 08, 2013 1:59
I have just upgrade to 13.04. And everything seems to work, but I can't mount my diskdrives.
I have my home directory on an other partition the system, but on boot on it doesn't mount, so I cannot mount to my homepartition when booting. With every update I use the same partition as home, so I don't have to adjust the settings to the various programs everytime.
In the past I adjust the udisk-policy. Last time I could do it in the systemsettings. But this doesn't work anymore??
So please is there anybody who can help me out here.
Wout
Re: automount diskdrive
Post by Fitzcarraldo » Wed May 08, 2013 9:22
In order to improve the chance of someone helping you, please post the output of the following commands issued as root user in a Konsole/Terminal window:
cat /etc/fstab
cat /etc/mtab
fdisk -l
blkid
What DE are you using? KDE?
woody3883
Post by woody3883 » Wed May 08, 2013 10:07
It is about /dev/sda4 with the mountpoint home1.
mtab:
rootfs / rootfs rw 0 0
proc /proc proc rw,relatime 0 0
none /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0
udev /dev devtmpfs rw,nosuid,relatime,size=10240k,nr_inodes=1010837,mode=755 0 0
devpts /dev/pts devpts rw,relatime,gid=5,mode=620,ptmxmode=000 0 0
sysfs /sys sysfs rw,relatime 0 0
/dev/sdb5 / ext4 rw,commit=0 0 0
shm /dev/shm tmpfs rw,nosuid,nodev,noexec,relatime 0 0
securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,nosuid,nodev,noexec,relatime 0 0
cgroup_root /sys/fs/cgroup tmpfs rw,nosuid,nodev,noexec,relatime,size=10240k,mode=755 0 0
openrc /sys/fs/cgroup/openrc cgroup rw,nosuid,nodev,noexec,relatime,release_agent=/lib64/rc/sh/cgroup-release-agent.sh,name=openrc 0 0
cpuset /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0
debug /sys/fs/cgroup/debug cgroup rw,nosuid,nodev,noexec,relatime,debug 0 0
cpu /sys/fs/cgroup/cpu cgroup rw,nosuid,nodev,noexec,relatime,cpu 0 0
cpuacct /sys/fs/cgroup/cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct 0 0
devices /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0
freezer /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0
blkio /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0
perf_event /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0
bfqio /sys/fs/cgroup/bfqio cgroup rw,nosuid,nodev,noexec,relatime,bfqio 0 0
tmpfs /tmp tmpfs rw,noexec,nosuid,nodev,size=100M 0 0
binfmt_misc /proc/sys/fs/binfmt_misc binfmt_misc rw,nodev,noexec,nosuid 0 0
/dev/sdc6 /run/media/wout/ACERDATA vfat rw,nodev,nosuid,uid=1000,gid=1001,shortname=mixed,dmask=0077,utf8=1,showexec,flush,flush,uhelper=udisks2 0 0
/dev/sdc5 /run/media/wout/ACER vfat rw,nodev,nosuid,uid=1000,gid=1001,shortname=mixed,dmask=0077,utf8=1,showexec,flush,flush,uhelper=udisks2 0 0
/dev/sdc1 /run/media/wout/OneTouch4 fuseblk rw,nosuid,nodev,allow_other,blksize=4096 0 0
fdisk -l:
Schijf /dev/sda: 2000.4 GB, 2000398934016 bytes, 3907029168 sectoren
Eenheid = sectoren van 1 * 512 = 512 bytes
Sectorgrootte (logischl/fysiek): 512 bytes / 512 bytes
in-/uitvoergrootte (minimaal/optimaal): 512 bytes / 512 bytes
Schijf-ID: 0x398e9119
Apparaat Opstart Begin Einde Blokken ID Systeem
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS/exFAT
/dev/sda2 208845 817676369 408733762+ 7 HPFS/NTFS/exFAT
/dev/sda3 817676370 1321378379 251851005 7 HPFS/NTFS/exFAT
/dev/sda4 1321378380 3907024064 1292822842+ 83 Linux
Schijf /dev/sdb: 400.1 GB, 400088457216 bytes, 781422768 sectoren
Schijf-ID: 0x00099764
/dev/sdb2 16065 773915309 386949622+ 5 uitgebreid
/dev/sdb3 773915310 781417664 3751177+ 82 Linux wisselgeheugen
/dev/sdb5 * 16128 312560639 156272256 83 Linux
/dev/sdb6 312560703 773915309 230677303+ 83 Linux
Schijf /dev/sdc: 500.1 GB, 500107862016 bytes, 976773168 sectoren
Schijf-ID: 0xd5642950
/dev/sdc1 * 63 813981419 406990678+ 7 HPFS/NTFS/exFAT
/dev/sdc2 813981420 931191659 58605120 f W95 uitgeb. (LBA)
/dev/sdc5 813981483 886322114 36170316 b W95 FAT32
/dev/sdc6 886322178 923014574 18346198+ b W95 FAT32
/dev/sdc7 923014638 931191659 4088511 12 Compaq diagnostiek
fstab:
UUID=ceae94eb-ef9d-4dfc-b9a5-525992dd4649 swap swap defaults 0 0
UUID=6fbe49bc-7650-458b-9be1-8e9052216049 / ext4 defaults 1 1
devpts /dev/pts devpts gid=5,mode=620 0 0
proc /proc proc defaults 0 0
sysfs /sys sysfs defaults 0 0
tmpfs /tmp tmpfs noexec,nosuid,nodev,size=100M 0 0
woody3883
Re: automount diskdrive (solved)
Post by woody3883 » Wed May 08, 2013 10:46
Ok thanks voor the help, but I found the solution.
Instead of adjust udev pollicy I adjusted udev2 policy.
Wout
Re: automount diskdrive [Solved]
Post by Fitzcarraldo » Wed May 08, 2013 11:13
OK, good to know. Fixing the subject in first post according to format specified in sticky thread Why, and how to add "[Solved]" to your post. Please read.
