How to setup your wirless card?
Postby BluePain » Fri Oct 20, 2006 12:14
Hello, I am having trubel with my wirless card. I have 2 nettorks back home. One that is encryptet and one that isent. BUt I cant connect to any of them. But When I use a cable. Then do I connect to the internett.
I have tryed to use the nettwork manager in the right corner at the top and a thing called RaLink Rt500 configuration. That is what my card are called. All this stuff was on the machine but when I try to add a nettwork. Do I not get connetet! What is the problem?
Postby Dark_MaGe » Fri Oct 20, 2006 19:04
first of all it would be better to post lspci and iwconfig outputs here so I can see what are we talking about...then I need you to tell me the output of iwlist so...supposing your card is ra0
iwlist ra0 scan
Your Farmer
Postby miso » Sat Oct 21, 2006 12:51
See my post on this forum. It might help.
