Sabayon 13.08 KDE - Can't write accents.
marceloramone
Post by marceloramone » Tue Aug 13, 2013 2:03
I can't write accents in KDE...
The keyboard is in spanish, KDE is in spanish but same problem i had in Sabayon 13.04 is present in 13.08: I'M unable to write with accents in KDE apps, for example: kwrite » atenci´on atenc{on
Here in chromium no problem: atención conclusión organización
I also changed the keyboard map using various models but no case.
Any idea about this problem?
pandev92
Re: Sabayon 13.08 KDE - Can't write accents.
Post by pandev92 » Tue Aug 13, 2013 12:55
Six months ago I had the same error...with kde on sabayon
Antidieu
Post by Antidieu » Sat Aug 31, 2013 1:29
Fitzcarraldo wrote:Try the following:
equo remove --nodeps --ask ibus
That did the trick for me. Thanks, Fitzcarraldo.
P.S. This thread should be marked as solved.
linuxfluesterer
Post by linuxfluesterer » Sat Aug 31, 2013 8:41
Hallo guys, hallo Fitz.
I had the same problem with the accents here in KDE, and I solved it the way you've described with removing ibus.
Now working for KDE and konsole of KDE also.
But still not working in a real terminal, opened with Ctrl+Alt+F1. The name (e.g.) "Réne" still appears in terminal as:
R'ene
How to fix that, pls?
manifesto
Post by manifesto » Sat Aug 31, 2013 10:43
It is a bit strange to have to remove ibus.
I need ibus to write non roman languages and I can as well write accents in KDE.
was ibus started when you add the problem or just installed ?
linuxfluesterer
Post by linuxfluesterer » Sat Aug 31, 2013 11:07
I don't really know, ibus was started (but I assume because remove effects that accents can be written in KDE now).
But definitely it was installed, because "equo remove..." asked me, and finally removed it.
Exactly, in a Virtualbox, I have a some days older Sabayon, KDE 64 bit, Daily Build from 23/08/2013 and in this version the accents were shown correctly in a KDE application. To mention: I did NOT upgrade this in Virtualbox.
So, I assume, the problem with lost accents in KDE appeared with upgrades of (many) packages of my Host in last days,
including a new kernel (3.10.9-r1) and a new KDE version (4.11) now.
Antidieu
Post by Antidieu » Sun Sep 01, 2013 10:52
It is in fact possible to write accents with IBus installed. You have to configure it to use your keyboard layout (in my case, Spanish - Latin American). Problem is IBus not being started although installed so you have to add it to Autostart.
