Ethernet Card Not recognised
Postby kamicota » Fri Jul 18, 2008 5:19
Hi Again ALL
Tried Sabayon LiveDVD (also PCLinuxOS 2008 Minime and PCLINuxOS 2007)
All do NOT find the Ethernet card--->>>
This is on an Asus P5KPL-CM MB (Quad core) with a --->>>
Atheros AR8121/AR8113 GIGABIT Ethernet card
Any ideas to solve this OR do I just install totally XP even though 220GB of hard drive is set up for Linux with /, swap and /home
Cheers for years
Colin :oops: :roll:
kamicota
Re: Ethernet Card Not recognised
Postby wolfden » Fri Jul 18, 2008 14:32
I believe kernel 2.6.26 and madwifi-ng is all you need for that
Postby DHalens » Fri Jul 18, 2008 16:23
I saw an issue with atheros a couple of days ago and the solution was to do update-pciids and reinstall madwifi.
Anyway, seems Asus has a linux driver: http://support.asus.com/download/download.aspx?product=1&SLanguage=us-en&type=map&model=P5KPL-CM
DHalens
Postby kamicota » Fri Jul 18, 2008 17:12
Kelly
Don't think I ca get that kernel as it will NOT connect to the internet let alone not see a lan card there :(
So looks as if back is up againt the wall eh
Cheers for years
Colin :D
kamicota
Postby kamicota » Fri Jul 18, 2008 17:15
Dhalens
I will look at this --->>>The "+" symbol represents folder with files attached inside. Clicking the "+" symbol will expand the folder or "-" symbol to hide it. You can find the latest driver or utility needed based on your operating system.
There are 2 download servers available on ASUS Download Site - Global and China. Each server provides the same content no matter where you download from, except for the speed which you are connected to.
Once I pluck up courage to try again
Cheers for years
Colin :D
kamicota
Postby kamicota » Fri Jul 18, 2008 17:26
Info from another Linux Forum--->>> I understand that NO Linux distribution supports the Altheros chip.
Cheers for years
Colin
kamicota
Postby DHalens » Fri Jul 18, 2008 23:20
Let's hope the link for drivers don't fail.
Download http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5KPL-CM/LinuxDrivers.zip and extract it.
Enter the folder LinuxDrivers/L1e_Lan and open a console.
Install unrar and do unrar e l1e-l2e-linux-v1.0.0.4.rar
Then, compile the driver with KBUILD_NOPEDANTIC=1 make
Copy the file atl1e.7 to parent directory: cp atl1e.7 ../atl1e.7 (make install will not work if you don't do this...).
Finally, KBUILD_NOPEDANTIC=1 make install
Hope it works.
DHalens
Postby kamicota » Sat Jul 19, 2008 1:05
Well y DHalens
I have the Drivers.zip on the desktop--->>>
But fail to SEE where this is leading me --->>> Guess the mind must be BLOGGED with ALL the NEGATIVE results from ALL that has been going on these last couple of days
Just for INFO hehehe - Centos 5.2 Did NOT SOLVE anything either :)
OH WELL WE yes this Lil' ol' MOIS is still tryin'
Cheers for Years
Colin
kamicota
Return to Hardware
