logitech keyboard, no dual boot [Solved]
Postby koch » Tue Dec 18, 2007 23:46
hello, i bought a logitech g11-keyboard and connected it to a usb-port. it works but in grub-menu i can't do a thing so i need my old keyboard for booting xp.
i did some search but found nothing. some help would be great, thanks.
edit: ok, one more search with other keywords did the job...usb-legacy-support had to be enabled in bios, now it works.
WINDOWS: Buy it, use it, break it, fix it, trash it, melt - upgrade it, charge it, pawn it, zoom it, press it, snap it, write it, get it, paste it, save it, load it, check it, plug it, play it, burn it, rip it, drag and drop it - stop. format it.
koch
Return to Hardware
