GUI Package Manager ~Portato~ Old Support Thread
Re: GUI Package Manager ~Portato~
Postby Necoro » Tue Sep 04, 2007 17:14
darkscot wrote:I have since upgraded to 3.4e and that seems to be OK. But i can post the file anyway if you still want it?
Sabayon 3.4e uses Portato 0.8.1 by default. If you did not upgrade portato you now have this version installed ... (and then I don't need the desktop file)
Necoro
Postby darkscot » Wed Sep 05, 2007 19:07
Well i was wrong! Since upgrading to 3.4e the problem with portato remains. It opens ok from the command line but clicking the icon does nothing.portato
Desktop1: Sabayon 3.4e, WinXP | Desktop2: Sabayon 3.4e, WinME |
darkscot
Postby Necoro » Wed Sep 05, 2007 19:24
Please give the output of
emerge -pv portato
/edit: I guess, that it is a gksu/kdesu issue...
Necoro
Postby darkscot » Wed Sep 05, 2007 20:51
Necoro wrote:Please give the output of
emerge -pv portato
sabayonx86-64 dt # emerge -pv portato
[ebuild     UD] app-portage/portato-0.7.5 [0.8.0-r1] USE="-etcproposals -gtk% -qt4% -userp               riv (-kde%*)" 95 kB [1]
Total: 1 package (1 downgrade), Size of downloads: 95 kB
Portage tree and overlays:
 [0] /usr/portage
 [1] /usr/portage/local/layman/sabayon
sabayonx86-64 dt #
darkscot
Postby Necoro » Wed Sep 05, 2007 21:10
Ok ... I recommend, that you upgrade your overlays (portato-0.8.5 is now in the normal sabayon overlay) and upgrade portato - and reinstall gksu (just in case):
layman -S
emerge -1av libgksu gksu
USE="-kde -userpriv" emerge -av portato
Then please test it again. If it still does not work, paste the content of /usr/share/applications/portato.desktop
Necoro
Postby darkscot » Thu Sep 06, 2007 19:48
Necoro wrote: If it still does not work, paste the content of /usr/share/applications/portato.desktop
What do you mean by this? portato.desktop is an application.
darkscot
Postby Necoro » Thu Sep 06, 2007 21:26
It's a text file ...
Necoro
Postby darkscot » Fri Sep 07, 2007 7:57
Necoro wrote:It's a text file ...
Not on my setup it is not! :?: Whenever I try to open it I get the message "are you sure you want to run this application?" If I say yes it opens portato!
darkscot
Postby Stupot » Fri Sep 07, 2007 15:28
right click on it, go to open with and choose kwrite or some other text editor.
Postby darkscot » Fri Sep 07, 2007 17:21
Here you go!
[Desktop Entry]
Name=Portato
Icon=portato-icon
Exec=portato
StartupNotify=true
Type=Application
Categories=Application;System;PackageManager
darkscot
