Trying to emerge eclipse
Postby Mr.Woo » Tue Dec 11, 2007 1:52
I was trying to emerge eclipse and I got this error. I have no idea what to do. I'm not even sure if this is the right place to be posting this problem but I thought it would be a good place to start.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                      >> E R R O R <<
/usr/bin/fastjar cf /var/tmp/portage/dev-java/antlr-2.7.7/work/antlr-2.7.7/antlr/antlr.jar antlr
Got an error while trying to execute  command  above.  Error
messages (if any) must have shown before. The exit code was:
exit(1)
make[1]: *** [/var/tmp/portage/dev-java/antlr-2.7.7/work/antlr-2.7.7/antlr/antlr.jar] Error 1
make: *** [all] Error 1
 * ERROR: dev-java/antlr-2.7.7 failed.
 * Call stack:
 *               ebuild.sh, line   35:  Called src_compile
 *             environment, line 4044:  Called die
 *       emake || diefunc "$FUNCNAME" "$LINENO" "$?" "compile failed";
 *  The die message:
 *   compile failed
 * A complete build log is located at '/var/tmp/portage/dev-java/antlr-2.7.7/temp/build.log'.
 * The ebuild environment file is located at '/var/tmp/portage/dev-java/antlr-2.7.7/temp/environment'.
!!! When you file a bug report, please include the following information:
GENTOO_VM=sun-jdk-1.6  CLASSPATH="" JAVA_HOME="/opt/sun-jdk-1.6.0.03"
JAVACFLAGS="+ -source 1.3 -target 1.3" COMPILER=""
and of course, the output of emerge --info
 * Messages for package dev-java/antlr-2.7.7:
 * Call stack:
 *  The die message:
 *   compile failed
Mr.Woo
Re: Trying to emerge eclipse
Postby Fitzcarraldo » Tue Dec 11, 2007 18:13
Well, the error message is telling you the problem is with antlr. If you use the SL Forum Search facility using the keyword "antlr" you'll find an answer.
Postby Mr.Woo » Wed Dec 12, 2007 6:13
The second post in this thread of the Gentoo forums solved my problem
http://forums.gentoo.org/viewtopic-t-525845.html
Mr.Woo
