Mythtv question
thawk21
Mythtv question
Post by thawk21 » Sun Dec 02, 2007 0:21
I am trying to install MythTV so i can use my TV tuner. I am having trouble getting it installed though. I am in portato and trying to "emerge" mythtv and it just keeps saying it couldn't download Mythtv. Does anyone know what I might be doing wrong? I am new to Gentoo so I don't even know if that is the correct way to install programs. I am more used to Debian OS's. So if anyone can help me out that would be great. Thanks
Re: Mythtv question
Post by wolfden » Sun Dec 02, 2007 2:14
Moved to proper forum
have you
emerge --sync && layman -S
you need to do that so you can update your package list before installing packages
momocore
Re: Mythtv question
Post by momocore » Sun Dec 02, 2007 4:00
Did you check out the wiki? it's fairly detailed:
http://wiki.sabayonlinux.org/index.php? ... tup_Mythtv
Hope that helps!
thawk21
Re: Mythtv question
Post by thawk21 » Sun Dec 02, 2007 9:01
Thanks I didnt see it in the WIKI. I tried that and got all the way to where it wants you to set up a password for mysql and it wont accept anything. And when I try to just skip that and go to start the backend it says files not found. So then I decided I would just try portato again and it is giving me this error:
!!! Error: the x11-drivers/xf86-video-via package conflicts with another package;
!!! the two packages cannot be installed on the same system together.
!!! Please use 'emerge --pretend' to determine blockers.
Any help would be appreciated.
Re: Mythtv question
Post by wolfden » Sun Dec 02, 2007 11:19
first, look at the error message, it's telling you exactly what to do.
second, do you need x11-drivers/xf86-video-via? If not uninstall them
third, have you cleaned your /etc/make.conf file?
http://www.sabayonlinux.org/forum/viewt ... 54&t=10578
thawk21
Re: Mythtv question
Post by thawk21 » Mon Dec 03, 2007 4:22
Again sorry if this is a stupid question but how do you clear out that file? And also I don't even know what the x11-drivers/xf86-video-via file is, so i will try removing it. Thanks a lot.
