Packages not compiling with emerge and layman issue
Postby linuxrocks » Sun Nov 25, 2007 6:29
hi all iv run into two problems lately
1. python-gnome & gnome-python-desktop would not compile with emerge they would come up with errors. but manually with the source code ./configure,make and make install worked with both packages?
2.layman does not list any overlays. and says there is no sabayon overly available. iv already tried reinstalling layman and Layman -L
Regards
Nick
linuxrocks
Re: Packages not compiling with emerge and layman issue
Postby momocore » Sun Nov 25, 2007 6:37
have you done layman -a sabayon
Maybe do a layman -d sabayon then layman -a sabayon
I bet the python errors are due to masked packages and/or dependencies. You should heed wolfden's advice and decipher what portage is telling you. Any chance you can post the error messages from portage?
momocore
Postby linuxrocks » Sun Nov 25, 2007 7:14
i allready deleted sabayon overlay and layman -a sabayon does not work
* Overlay "sabayon" does not exist!
i get that error
here is the emerge log for
>>> Emerging (1 of 2) dev-python/gnome-python-2.20.0 to /
* gnome-python-2.20.0.tar.bz2 RMD160 SHA1 SHA256 size ;-) ... [ ok ]
* checking ebuild checksums ;-) ... [ ok ]
* checking auxfile checksums ;-) ... [ ok ]
* checking miscfile checksums ;-) ... [ ok ]
* checking gnome-python-2.20.0.tar.bz2 ;-) ... [ ok ]
>>> Unpacking source...
>>> Unpacking gnome-python-2.20.0.tar.bz2 to /var/tmp/portage/dev-python/gnome-python-2.20.0/work
* Fixing OMF Makefiles ... [ ok ]
* Running elibtoolize in: gnome-python-2.20.0
* Applying portage-1.5.10.patch ...
* Applying max_cmd_len-1.5.20.patch ...
* Applying sed-1.5.6.patch ...
>>> Source unpacked.
>>> Compiling source in /var/tmp/portage/dev-python/gnome-python-2.20.0/work/gnome-python-2.20.0 ...
* econf: updating gnome-python-2.20.0/config.guess with /usr/share/gnuconfig/config.guess
* econf: updating gnome-python-2.20.0/config.sub with /usr/share/gnuconfig/config.sub
./configure --prefix=/usr --host=i586-pc-linux-gnu --mandir=/usr/share/man --infodir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc --localstatedir=/var/lib --disable-gtk-doc --build=i586-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking build system type... i586-pc-linux-gnu
checking host system type... i586-pc-linux-gnu
checking for style of include used by make... GNU
checking for i586-pc-linux-gnu-gcc... i586-pc-linux-gnu-gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether i586-pc-linux-gnu-gcc accepts -g... yes
checking for i586-pc-linux-gnu-gcc option to accept ISO C89... none needed
checking dependency style of i586-pc-linux-gnu-gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by i586-pc-linux-gnu-gcc... /usr/i586-pc-linux-gnu/bin/ld
checking if the linker (/usr/i586-pc-linux-gnu/bin/ld) is GNU ld... yes
checking for /usr/i586-pc-linux-gnu/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... i586-pc-linux-gnu-gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for i586-pc-linux-gnu-g++... i586-pc-linux-gnu-g++
checking whether we are using the GNU C++ compiler... yes
checking whether i586-pc-linux-gnu-g++ accepts -g... yes
checking dependency style of i586-pc-linux-gnu-g++... gcc3
checking how to run the C++ preprocessor... i586-pc-linux-gnu-g++ -E
checking for i586-pc-linux-gnu-g77... no
checking for i586-pc-linux-gnu-f77... no
checking for i586-pc-linux-gnu-xlf... no
checking for i586-pc-linux-gnu-frt... no
checking for i586-pc-linux-gnu-pgf77... no
checking for i586-pc-linux-gnu-cf77... no
checking for i586-pc-linux-gnu-fort77... no
checking for i586-pc-linux-gnu-fl32... no
checking for i586-pc-linux-gnu-af77... no
checking for i586-pc-linux-gnu-f90... no
checking for i586-pc-linux-gnu-xlf90... no
checking for i586-pc-linux-gnu-pgf90... no
checking for i586-pc-linux-gnu-pghpf... no
checking for i586-pc-linux-gnu-epcf90... no
checking for i586-pc-linux-gnu-gfortran... i586-pc-linux-gnu-gfortran
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether i586-pc-linux-gnu-gfortran accepts -g... yes
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from i586-pc-linux-gnu-gcc object... ok
checking for objdir... .libs
checking for i586-pc-linux-gnu-ar... i586-pc-linux-gnu-ar
checking for i586-pc-linux-gnu-ranlib... i586-pc-linux-gnu-ranlib
checking for i586-pc-linux-gnu-strip... i586-pc-linux-gnu-strip
checking if i586-pc-linux-gnu-gcc supports -fno-rtti -fno-exceptions... no
checking for i586-pc-linux-gnu-gcc option to produce PIC... -fPIC
checking if i586-pc-linux-gnu-gcc PIC flag -fPIC works... yes
checking if i586-pc-linux-gnu-gcc static flag -static works... yes
checking if i586-pc-linux-gnu-gcc supports -c -o file.o... yes
checking whether the i586-pc-linux-gnu-gcc linker (/usr/i586-pc-linux-gnu/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by i586-pc-linux-gnu-g++... /usr/i586-pc-linux-gnu/bin/ld
checking whether the i586-pc-linux-gnu-g++ linker (/usr/i586-pc-linux-gnu/bin/ld) supports shared libraries... yes
checking for i586-pc-linux-gnu-g++ option to produce PIC... -fPIC
checking if i586-pc-linux-gnu-g++ PIC flag -fPIC works... yes
checking if i586-pc-linux-gnu-g++ static flag -static works... yes
checking if i586-pc-linux-gnu-g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for i586-pc-linux-gnu-gfortran option to produce PIC... -fPIC
checking if i586-pc-linux-gnu-gfortran PIC flag -fPIC works... yes
checking if i586-pc-linux-gnu-gfortran static flag -static works... yes
checking if i586-pc-linux-gnu-gfortran supports -c -o file.o... yes
checking whether the i586-pc-linux-gnu-gfortran linker (/usr/i586-pc-linux-gnu/bin/ld) supports shared libraries... yes
checking for a Python interpreter with version >= 2.2... python
checking for python... /usr/local/bin/python
checking for python version... 2.5
checking for python platform... linux2
checking for python script directory... ${prefix}/lib/python2.5/site-packages
checking for python extension module directory... ${exec_prefix}/lib/python2.5/site-packages
checking for headers required to compile python extensions... found
checking for python libraries... -L/usr/lib -lm -lpthread -ldl -lutil -lpython2.5
checking for i586-pc-linux-gnu-pkg-config... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for PYGTK... yes
checking for pygtk-codegen-2.0... /usr/local/bin/pygtk-codegen-2.0
checking for conflicting pygtk versions... none
checking for pygtk defs... /usr/share/pygtk/2.0/defs
checking for i586-pc-linux-gnu-pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.7... yes
checking for GLIB - version >= 2.6.0... yes (version 2.14.3)
checking for pkg-config... (cached) /usr/bin/pkg-config
checking for GTK+ - version >= 2.6.0... yes (version 2.12.1)
checking for GNOME... yes
checking for prctl... yes
checking for setproctitle... no
checking for PYORBIT... yes
checking for GNOMEUI... yes
checking for GNOMECANVAS... yes
checking for GNOMEVFS... yes
checking for GNOMEVFSBONOBO... yes
checking for GNOME_VFS_MODULE... yes
checking for GCONF... yes
checking for BONOBO_ACTIVATION... yes
checking for BONOBO... yes
checking for BONOBOUI... yes
checking whether i586-pc-linux-gnu-gcc -pthread understands -Wall... yes
checking whether i586-pc-linux-gnu-gcc -pthread understands -std=c9x... yes
checking whether i586-pc-linux-gnu-gcc -pthread understands -fno-strict-aliasing... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating docs/Makefile
config.status: creating docs/gnomevfs/Makefile
config.status: creating gconf/Makefile
config.status: creating gnome/Makefile
config.status: creating gnomevfs/Makefile
config.status: creating gnomecanvas/Makefile
config.status: creating bonobo/Makefile
config.status: creating tests/Makefile
config.status: creating gnome-python.spec
config.status: creating gnome-python-2.0.pc
config.status: creating PKG-INFO
config.status: creating config.h
config.status: executing depfiles commands
The following modules will be built:
gnome
gnome.ui
gnomecanvas
gnomevfs
gnome-vfs python module support
gconf
bonobo
bonobo.activation
bonobo.ui
The following modules will NOT be built:
Making all in gnome
File "/usr/local/share/pygtk/2.0/codegen/codegen.py", line 1261, in <module>
sys.exit(main(sys.argv))
File "/usr/local/share/pygtk/2.0/codegen/codegen.py", line 1214, in main
"load-types=", "errorfilename="])
File "/usr/lib/python2.5/getopt.py", line 89, in getopt
opts, args = do_longs(opts, args[0][2:], longopts, args[1:])
File "/usr/lib/python2.5/getopt.py", line 153, in do_longs
has_arg, opt = long_has_args(opt, longopts)
File "/usr/lib/python2.5/getopt.py", line 170, in long_has_args
raise GetoptError('option --%s not recognized' % opt, opt)
getopt.GetoptError: option --py_ssize_t-clean not recognized
make[2]: *** [gnome.c] Error 1
make[2]: *** Waiting for unfinished jobs....
mkdir .libs
i586-pc-linux-gnu-gcc -pthread -DHAVE_CONFIG_H -I. -I.. -I/usr/include/python2.5 -I/usr/include/python2.5 -I/usr/include/pygtk-2.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -DORBIT2=1 -pthread -I/usr/include/libgnome-2.0 -I/usr/include/orbit-2.0 -I/usr/include/gconf/2 -I/usr/include/gnome-vfs-2.0 -I/usr/lib/gnome-vfs-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/libbonobo-2.0 -I/usr/include/bonobo-activation-2.0 -Os -march=i586 -mno-tls-direct-seg-refs -mmmx -m32 -Wall -std=c9x -fno-strict-aliasing -MT _gnome_la-gnomemodule.lo -MD -MP -MF .deps/_gnome_la-gnomemodule.Tpo -c gnomemodule.c -fPIC -DPIC -o .libs/_gnome_la-gnomemodule.o
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
* ERROR: dev-python/gnome-python-2.20.0 failed.
* Call stack:
* ebuild.sh, line 1701: Called dyn_compile
* ebuild.sh, line 1039: Called qa_call 'src_compile'
* ebuild.sh, line 44: Called src_compile
* ebuild.sh, line 1383: Called gnome2_src_compile
* gnome2.eclass, line 71: Called die
* emake || die "compile failure"
* The die message:
* compile failure
* A complete build log is located at '/var/tmp/portage/dev-python/gnome-python-2.20.0/temp/build.log'.
* Messages for package dev-python/gnome-python-2.20.0:
* Call stack:
* The die message:
* compile failure
linuxrocks
Postby freeallbadgers » Sun Nov 25, 2007 19:12
From your errors....
Looks like you're running python 2.5, have you ran
python-updater -i
since upgrading python?
If not that's probably why things have started breaking on you.
“I just finished compiling glibc and now it says there is a new update available? Arrgh! It never ends!!”
freeallbadgers
