How to Update Compiz Fusion **8/22/07**
Re: How to Update Compiz Fusion **8/22/07**
Postby velk » Wed Aug 22, 2007 11:47
i tried the method of the first post , it is not working for me
access-dev1 scripts # ./fusionupdate.sh merge
Updating xeffects overlay
* Running command "/usr/bin/svn update "/usr/portage/local/layman/xeffects""...
À la révision 86.
* Success:
* Successfully synchronized overlay "xeffects".
Purging packages
--- Couldn't find 'compiz-fusion' to unmerge.
--- Couldn't find 'compiz' to unmerge.
--- Couldn't find 'libcompizconfig' to unmerge.
--- Couldn't find 'compizconfig-python' to unmerge.
--- Couldn't find 'compiz-bcop' to unmerge.
--- Couldn't find 'compizconfig-backend-kconfig' to unmerge.
--- Couldn't find 'compiz-fusion-plugins-main' to unmerge.
--- Couldn't find 'compiz-fusion-plugins-extra' to unmerge.
--- Couldn't find 'x11-apps/ccsm' to unmerge.
--- Couldn't find 'x11-wm/emerald' to unmerge.
--- Couldn't find 'x11-themes/emerald-themes' to unmerge.
>>> No packages selected for removal by unmerge
Emerging packages
Calculating dependencies |
!!! All ebuilds that could satisfy "~x11-plugins/compiz-fusion-plugins-extra-999 9" have been masked.
- x11-plugins/compiz-fusion-plugins-extra-9999 (masked by: missing keyword)
For more information, see MASKED PACKAGES section in the emerge man page or
refer to the Gentoo Handbook.
(dependency required by "x11-wm/compiz-fusion-9999" [ebuild])
velk
Postby wolfden » Wed Aug 22, 2007 11:52
can you retry starting at the beginning again - had to make some revisions
Make sure you follow the very first thing about the /etc/portage/package.keywords
Postby velk » Wed Aug 22, 2007 12:26
ok working fine now thanks
just need to find a way to start compiz-fusion-icon at kde starts, because i actually launch compiz with command line
velk
Postby wolfden » Wed Aug 22, 2007 12:37
KDE should remember you session when you log out - can try adding it to the /home/username/.kde/Autostart if totally stuck
make sure to reinstall your fusion-icon
Postby velk » Wed Aug 22, 2007 18:49
I have also a problem with fusion-icon
access-dev1 nico # emerge fusion-icon
Calculating dependencies -
!!! All ebuilds that could satisfy "fusion-icon" have been masked.
- x11-apps/fusion-icon-9999 (masked by: missing keyword)
velk
Postby wolfden » Wed Aug 22, 2007 21:13
You have to do what is stated above - For extras, you have to add them to your /etc/portage/package.keywords
Postby sjeter » Thu Aug 23, 2007 2:01
OK, everything worked fine up to and including emerge compiz-fusion-icon.
Then when I did this
localhost / # emerge compiz-fusion-plugins-atlantis
I got this
!!! All ebuilds that could satisfy "~x11-wm/compiz-9999" have been masked.
- x11-wm/compiz-9999 (masked by: missing keyword)
(dependency required by "x11-plugins/compiz-fusion-plugins-atlantis-9999" [ebuild])
Here is my /etc/portage/package.keywords (from both updates above)
#dev-python/compizconfig-python **
#x11-wm/compiz **
#x11-wm/compiz-fusion **
#x11-plugins/compiz-fusion-plugins-main **
#x11-plugins/compiz-fusion-plugins-extra **
#x11-plugins/compiz-fusion-plugins-unsupported **
x11-plugins/compiz-fusion-plugins-threed **
#x11-wm/emerald **
#x11-themes/emerald-themes **
#x11-apps/ccsm **
#x11-libs/libcompizconfig **
#x11-libs/compizconfig-backend-gconf **
#x11-libs/compizconfig-backend-kconfig **
#x11-libs/compiz-bcop **
x11-apps/fusion-icon **
#x11-libs/bcop **
x11-plugins/compiz-fusion-plugins-atlantis **
x11-plugins/compiz-users-pafy-screensaver **
sjeter
Postby wolfden » Thu Aug 23, 2007 3:25
will this work for ya?
emerge compiz-fusion-plugins-atlantis --nodeps
Postby sjeter » Thu Aug 23, 2007 3:39
Yup - txu
sjeter
Postby Phough » Thu Aug 23, 2007 17:04
I've got another problem with fusion-icon. I have searched many forums but still have no idea how to solve that. Prob is, when i try to launch fusion-icon I get this error:
* Using the Qt4 Interface
* No module named interface_qt4
... Trying another interface
* Using the Qt3 Interface
* No module named interface_qt3
* Using the GTK Interface
* No module named interface_gtk
* Error: All interfaces failed, aborting!
Compiz-fusion starts with "compiz-start" command and it works but theres no systray icon. Any ideas?. I run that script under KDE (sabayon 3.4a)
Phough
