KDE SC 4.5?
OOPMan
KDE SC 4.5?
Post by OOPMan » Thu Aug 12, 2010 14:10
Any idea when we'll be getting this?
I hear there are some delays on the Gentoo side due to instability in kdepim-4.5 but I've also read that this can be circumvented by just using kdepim-4.4.x in place...
Re: KDE SC 4.5?
Post by joost » Thu Aug 12, 2010 15:32
When upstream Gentoo thinks it is good enough to have in portage we will most likely follow.
OOPMan
Re: KDE SC 4.5?
Post by OOPMan » Thu Aug 12, 2010 15:50
Cool. I guess I'll just keep my fingers crossed and hope they're happy soon :-)
Re: KDE SC 4.5?
Post by Fitzcarraldo » Sat Aug 14, 2010 16:00
KDE 4.5.0 is not going to be added to the main Portage tree:
http://blog.tampakrap.gr/kde-4-5-0-in-gentoo/
Gentoo KDE Guide
You can get it from the Gentoo KDE overlay, though.
Gentoo KDE Guide wrote:Note: KDE 4.5.0, the newest KDE release, will not be included in the portage tree, because it lacks the KDEPIM suite. Thus, it will remain in the kde overlay hardmasked. It can be installed with KDEPIM 4.4.5 though, if the user adjusts the keyword files accordingly. The first KDE 4.5.X version that will include the KDEPIM suite will be added to portage as well.
ermin
Re: KDE SC 4.5?
Post by ermin » Sat Aug 14, 2010 18:44
Does someone know how to install it, without upsetting entropy too much?
Re: KDE SC 4.5?
Post by wolfden » Sat Aug 14, 2010 19:00
ermin wrote:Does someone know how to install it, without upsetting entropy too much?
That would not be a good idea and not supported. Did you read the blog post and understand it?
ermin
Re: KDE SC 4.5?
Post by ermin » Sun Aug 15, 2010 5:34
No. What blog post do you mean?
I read the Wiki-Article about mixing entropy and portage. Using it I had success with packages not found in the official repos and even managed to install an older version of skype. No problems so far.
Therefor I hoped it could be possible...
DanySK
Re: KDE SC 4.5?
Post by DanySK » Sun Aug 15, 2010 6:35
The Gentoo blog one. A few pieces of KDE SC are stuck to 4.4.x branch. Updates will most likely cause a lot of troubles, an as a consequence it is wise to wait for the first 4.5.x release which will integrate also PIM.
ermin
Re: KDE SC 4.5?
Post by ermin » Sun Aug 15, 2010 6:56
KDEPIM is Korganizer, KMail, Kontact and so on, isn't it? Never used that stuff. Can't I just somehow omit it? Would that solve anything?
Re: KDE SC 4.5?
Post by Stupot » Sun Aug 15, 2010 7:52
The point that is being made is that KDE 4.5.0 isn't being supported by Sabayon or Gentoo. You are always free to go out and try to do anything you want with your linux distro, but installing 4.5.0 isn't supported and you will have a hard time finding help.
What is so important in the KDE 4.5 release that makes you want it right away? I read through the release announcements and saw nothing worth migrating to before it was really ready.
If you wish to continue in your pursuit, I suggest looking at the kde overlay for portage. Once again though, if things go wrong, you'll be on your own.
