X server not accepting more local connections?
agryppa
Post by agryppa » Wed Aug 05, 2009 13:22
here is the situation: system is up and running, user logged in into X + kde4.2. There has been a terminal session present from a previous xsession so the terminal is already open. Now the command kmail & gives this:
kmail
No protocol specified
kmail: cannot connect to X server :0
<unknown program name>(7725)/: KUniqueApplication: Registering failed!
<unknown program name>(7725)/: Communication problem with  "kmail" , it probably crashed.
Error message was:  "org.freedesktop.DBus.Error.ServiceUnknown" : " "The name org.kde.kmail was not provided
by any .service files" "
What tool would be best to diagnose the problem, how to resolve it? No other program icon is responsive, not even a next xterminal or konsole. One can only press Start-Logout.
Firefox strace for example is revealing such output, here is a snippet:
fstat(4, {st_mode=S_IFREG|0600, st_size=434, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fa15dce4000
read(4, "\1\0\0\7sabayon\0\0010\0\22MIT-MAGIC-COOKIE-"..., 4096) = 434
read(4, ""..., 4096)                    = 0
close(4)                                = 0
munmap(0x7fa15dce4000, 4096)            = 0
fcntl(3, F_GETFL)                       = 0x2 (flags O_RDWR)
fcntl(3, F_SETFL, O_RDWR|O_NONBLOCK)    = 0
fcntl(3, F_SETFD, FD_CLOEXEC)           = 0
select(4, [3], [3], NULL, NULL)         = 1 (out [3])
writev(3, [{"l\0\v\0\0\0\0\0\0\0"..., 10}, {"\0\0"..., 2}], 2) = 12
read(3, "\0\26\v\0\0\0\6\0"..., 8)      = 8
read(3, "No protocol specified\n\1\0"..., 24) = 24
write(2, "No protocol specified\n"..., 22) = 22
close(3)                                = 0
write(2, "Error: cannot open display: :0\n"..., 31) = 31
munmap(0x7fa152389000, 2113984)         = 0
getpid()                                = 7771
munmap(0x7fa15dcb8000, 180224)          = 0
munmap(0x40439000, 8192)                = 0
munmap(0x7fa15ad61000, 19744920)        = 0
munmap(0x7fa15c929000, 2624680)         = 0
The interesting part is that when a user logs out and back in again the issue disapears for a while - till next login that is.
thank you very much
Agryppa
