Metisse no more in Portage, but possible to install [Solved]
Post by albfneto » Sat Aug 01, 2009 22:45
Metisse is not more available?
I dont find it in the new Entropy version,
neither in Portage, in the Sabayon's Overlay e even i not found in Hana's Overlay, in wich it was present, some months ago.
Re: Metisse
Post by Fitzcarraldo » Sat Aug 01, 2009 23:01
It seems Metisse is effectively dead in Gentoo: http://forums.gentoo.org/viewtopic-p-56 ... ml#5647970
Re: Metisse
Post by albfneto » Sun Aug 02, 2009 0:11
Thanks. If i want to save metisse, i need compile it by hand.
is it possible to convert the metisse RPM mandrivas's pack, to working in gentoo or sabayon?
Re: Metisse
Post by Fitzcarraldo » Sun Aug 02, 2009 0:20
See the link "CVS live ebuilds" in the Gentoo Forum post http://forums.gentoo.org/viewtopic-p-57 ... ml#5783972. You'll need to download those and create local ebuilds in a local overlay on your HDD.
Re: Metisse no more in Portage, but possible to install [Solved]
Post by albfneto » Sun Aug 02, 2009 15:47
Thanks!!
The Metisse was easy installed, using the suggested procedure.
I had the structure forlocal overlay mounted, from this is easy.
I installed Metisse in Sabayon, and in Gentoo also, using the same method
