osd volume control kde 4
napass
Post by napass » Tue Jul 21, 2009 11:39
hi,
which is the name of application that show "osd volume control" in KDE 4 ???
thanks!!! :D
Re: osd volume control kde 4
Post by Fitzcarraldo » Wed Jul 22, 2009 11:35
Not sure what you're referring to. Do you mean the KMix audio mixer? If not, please explain what it looks like and what it does.
napass
Post by napass » Thu Jul 23, 2009 20:48
it isn't kmix... :)
but.. i'm interesting at this:
thanks! :D
Post by Fitzcarraldo » Thu Jul 23, 2009 21:19
I have that too, and it works out-of-the-box when I install SL. Anyway, here's how to (try to) set it up manually:
Kickoff > Computer > System Settings | Computer Administration | Keyboard & Mouse | Global Keyboard Shortcuts
Click on Decrease Volume. If the radio button 'Default: Volume Down' is selected but the Decrease Volume key on your keyboard does not have any effect then click on the 'Custom:' radio button and click on None and then press the key that you want to use to decrease the volume. Repeat the procedure for 'Increase Volume'.
As I wrote above, I didn't have to do any of this for my laptop, it was already configured upon installation of SL. So I hope you can get it working.
napass
Post by napass » Sat Jul 25, 2009 8:48
ok thanks... :)
