kdm no longer operating...
hulkyboy
Post by hulkyboy » Wed Jul 15, 2009 10:30
This is a fairly fresh installation of Sabayon 4.2 64 KDE.
I noticed a few problems, where the system settings would display a blank window in KDE and also Konqueror was permantly stuck on the fsview plugin, and crashed everytime I selected configure on the menu.
I tried reinstalling the system settings package, and the konqueror package to no avail.
Next, I killed off any .kde* folders in home, expecting defaults to be applied on next startup...
Thing is, on starting again, I get this...
"which: no kdm in (/lib64/rc/sbin:/lib64/rc/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/opt/bin:/usr/x86_64-pc-linux-gnu/gcc-bin/4.3.2:/opt/blackdown-jdk-1.4.2.03/bin:/opt/blackdown-jdk-1.4.2.03/jre/bin:/usr/qt/3/bin)
* Setting up xdm..."
I have no idea what's happened to kdm (it IS present in the kde4.2 bin dir, and it IS present in /etc/conf.d/xdm). I am presuming that some symlink has been destroyed someplace, but no idea where...
anybody have any idea?
hulkyboy
Re: kdm no longer operating...
Post by hulkyboy » Wed Jul 15, 2009 22:51
It would seem $KDEDIR is no longer defined. If I do define it, then I get "No greeter widget plugin loaded. Check configuration." from kdm. It then dies.
No idea what's happened, but I don't want to reinstall only for it to happen again...
hulkyboy
Re: kdm no longer operating... (Kinda Fixed)
Post by hulkyboy » Thu Jul 16, 2009 22:23
Ok, I got it working again... None the wiser as to what caused it in the first place, and not entirely sure it's correct...
reemerged kdebase-meta
Still had an issue with a kdm theme not being found, and that led to the discovery that there appear to be multiple locations for these...
I've got
/usr/kde/4.2/share/apps/kdm/themes
and
/usr/share/apps/kdm/themes
Is this normal? I had to symlink an existing theme (Glassified) to get kdm to load.
May user path is now
/usr/local/bin:/usr/bin:/bin:/opt/bin:/usr/x86_64-pc-linux-gnu/gcc-bin/4.3.2:/opt/blackdown-jdk-1.4.2.03/bin:/opt/blackdown-jdk-1.4.2.03/jre/bin:/usr/kde/3.5/bin:/usr/qt/3/bin:/usr/games/bin
which is different from the Live cd one, and also $KDEDIR is still undefined...
Main thing is, I can at least get into the thing...
Thev00d00
Generally Awesome (tm)
Post by Thev00d00 » Fri Jul 17, 2009 14:24
This issue has been noted before, please raise a bug on bugzilla FAO Joost Ruis, everything ebuild wise is fine. :D
Website / Blog : v00d00.net
twitter: Follow Me
G+: Circle Me
